Results 1 to 5 of 5
    Mar 2008
    SF South Bay
    Service interval on wheel hub bearings
    I'm replacing my rotors all around with some aftermarket drilled and slotted units from BrakePlanet in an effort to once and for all end my squeaky brake problems forever.
    While I was at it I was wondering how often your supposed to replace the wheel hub bearing assemblies. Please correct me if I'm wrong since I never actually looekd but I am assuming the bearings are sealed and are replacement only since they likely contain an ABS sensor????? The replacement parts aren't cheap so I'm just assuming here.
    As always, any insight is greatly appreciated.
    2006 Dodge Magnum R/T 5.7 AWD
    AFE Stage II~JBA Headers~Borla Cat Back~Diablo Tuner~180 TStat~NoESP~Drilled & Slotted Rotors
    striker071 is offline LX Padiwan
    Nov 2007
    I beleive they are replaced when they fail.... so hopefully not for a couple hundred thousand miles
    fnkychkn's Avatar
    greasy cardboard box
    hub/bearing assemblies are sealed and require no maintenance.
    btw, welcome to LXforums.
    Mar 2008
    SF South Bay
    thanks and thanks, its good to be here.
    -Tory
    hemiboy29's Avatar
    hemiboy29 is offline Gotta Hemi???
    Jan 2006
    Miami,Florida
    I am about to hit 50,000 miles and my front end is humming I thing I need to change my hub bearings already :( I wonder how much the run for...
    Posted via LXFMobile
