After suffering from braking induced vibrations I tried bedding the pads/rotors per Zeckhausen...better, but not good enough.
I went to the local dealer to have them check whether it was rotors or rack & pinion / suspension problems; verdict front rotors.
They replaced the front rotors & pads using the following part numbers:
Rotors p/n 4779197AD @ $86.50 each (They did have "Bosch" imprinted)
Pad Kit p/n V1012558 @ $55.00 for the pair.
Question: Are these the right part numbers?
The reason I ask is that they said that the Magnum RT AWD did NOT use ceramic pads. (I thought they did.)
If they did use the wrong pads or a lesser than OEM alternative, what are my options?![]()
