I don't want anything too drastic. Just maybe drop it the inch or so that they added to the AWD ride height. I've seen the Ground Force springs on EBAY for mid $200's.
2005 Inferno red AWD RT
2002 Collector Edition Trans Am(F-bodyhideout member)
i saw those too, and with shipping its just short of $300.
it said 1.2 in front, 1.3 in rear. it would end up just a little lower than a rwd, might be perfect.
some guys here have the v2 coilovers and love them, but they are also a lot more money...
I have the KW V2 on mine and love them, but I had on the ground force for a week prior to my Kw's.
I would be willing to sell them to you for $200.00 + shipping!
Any Takers?
I would do more homework guys.
I do not think those springs will work for the AWD Magnums.
I beleive the KW's and Air are the only ways to correctly lower the AWD Magnums.
the ground force springs are made especially for the AWD
see link http://www.groundforce.com/vehicle.a...ge&make=Magnum
I stand corrected.
I guess I just haven't heard about anyone here thats ever used them.
I have used the fronts only to get a raked look and help with traction.
The REAR DOES NOT WORK WITH NIVOMATS(self leveling shocks). Unless you mod them. There is a thread about that recently.
Lou -05 Magnum RT AWD ---> FRI'd 392
I have the KW V2s and am happy with the handling (slightly rougher on rough roads)but corners feel much more glued to the road. Love the look of the 2" drop on the AWD. Once you use lowering springs (there weren't any available for AWD previously) you can potentially expect problems with your shocks not having enough travel/literally pounding them to pieces.
Hemi registry#00729
LxReJx
i have a set of Eibach pro kit for AWD that im willing to sell,
200$ + shipping
Im in montreal and the roads are VERY bad and have often 5 people in my carso they arent good for me at all.
i will go check tomorow they are in the shed and dont have any lights over there!
200 shipped will depend on how much the shipping cost, where are you located?
ok the part number for the eibach pro kit is #2879.140
I have the same Eibach's and they worked out fine for me. I was able to use a lift at a local garage to do the install, it took a few hours.
On my AWD, the rear was lowered more than the front, I don't know why. Sitting in a parking lot you can kind of see the rear sitting a bit lower and it even measures lower.
The drop is perfect though....I lost NO ride comfort, looks awesome with oversized wheels, mine are 20's and it's realitively easy to do.
We Can Only Change Tomorrow !!
Rides:
2005 Magnum RT AWD * 1994 TransAm 25th Anniv. * '74 Firebird Formula 400 * '73 TransAm 455 * '33 Ford P/U Street Rod ( Blown 350)
