Results 1 to 11 of 11
    striker071 is offline LX Padiwan
    Nov 2007
    Hi flow cats... headers which one?
    What headers and hi flow cats would be a good fit for a AWD Charger? Any Sugestions
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by striker071 View Post
    Check with Josh at HHP. They had some high flow cats custom made for the AWD. I have a set and the JBA short headers. Long tubes will not fit.
    Midnightsun300c's Avatar
    Midnightsun300c is offline Large Carbon Footprint
    Eagle River, Alaska
    They will if you replace your transmission brace with a custom one.
    Honorary First Member – LX AWD – 11 Second Club
    MikeEast's Avatar
    Ducktown, Georgia
    JBA shorties and highflows make a real nice change, I think you'd be impressed.
    I got mine from HHP and can recommend Josh big time.
    Mike
    Mar 2008
    SF South Bay
    I have JBA shorty headers and I was going to get the highflow CAT but I couldn't justify it. I'm not convinced its worth it. They should have a shoot out for them over in the Mods FaceOff Forum but its such a PITA to install them.
    A couple of things about the JBA's though, they are a beast to install due to clearance issues. But only for two bolts on each side if you do like the JBA install instructions indicate and remove the mounts from each side one at a time. Not easily done with out a lift IMHO....
    I also developed a drone when MDS kicks in. Since I had a Borla CAT Back with resonators installed at the same time I'm not sure which caused it exactly though. But if MDS kick in at anything above 75MPH I start to here a low drone, when I'm doing more than 85 its very noticeable. Its OK though, its the sound of savings and I kind of like being able to easily tell when MDS kicks in. I try to stay in the drone when cruising with gas over $4 bucks a gallon lately. I gained 2-3 MPG easy when cruising with MDS engaged. Where I had virtually never seen better than 19 MPG range (on the LCD guage) except when going down hill I now cruise the stretch of freeway on my dialy drive in both directions at 21.6MPG. Thats way up from the usual 18.4 I used to see before the headers. And this is with the stock tune.
    Very few choice other the JBA's BTW..... I was going to try Hedmens but they actually stopped making them! I called them and everything and they told me that the part number for 5.7's was sent back to R&D and there was no ETA on their reintroduction.
    2006 Dodge Magnum R/T 5.7 AWD
    AFE Stage II~JBA Headers~Borla Cat Back~Diablo Tuner~180 TStat~NoESP~Drilled & Slotted Rotors
    Phanta5m's Avatar
    Phanta5m is offline LX Padiwan
    Sep 2007
    Black Pearl
    actually aren't those high-flow cats from hhp... magnaflow. and they will produce some good horsepower... just with the cats alone
    Nov 2007
    I have tlkaed with Josh before at HHP was gonna do kw2's. But my family lives in Delaware so when I make a trip maybe I can arrange to get this done. So do you all think that JBA's/ High flow cats and Zoomers would be a good combo?
    2005 big body's Avatar
    2005 big body is offline Never Scared
    Detroit, MI
    i have the dynatech longtube headers and high flo and love them.
    go big or go home!
    Super T's Avatar
    Aurora, IL
    Certainly not a bad combo, that's for sure.
    MikeEast's Avatar
    Ducktown, Georgia
    That's the exact combination I have and I can highly recommend them.
    Mike
    1blkperl's Avatar
    1blkperl is offline 1blkperl
    Jul 2007
    VC NV (outside Reno )
    I have JBA headers and cats and love them.
