Results 1 to 14 of 14
    mac424's Avatar
    mac424 is offline LX Padiwan
    Apr 2008
    Pittsburgh, PA
    Help with some wheels and tires!
    Hey guys I've been loooking at a set of wheels for my AWD Mag and I found a set that I like, but I'm concerned about them fitting since the offset is differnt from the R/T RWD.
    The size is 20x8.5 with a 40mm offset. I'm sure they'll fit, but will I have to worry about the wheels sticking out past the fender wells? What is a good size tire for this setup? I'm not planning on lowering the car so I'd like to fill the gap a little, but not make the wheels look lost with a high sidewall tire.
    Thanks for your help!
    2006 Dodge Magnum R/T AWD
    Magnesium Pearlcoat
    Mods: 20" Foose DF-5's, Intake and Blastin Bob's 9b Resonator Elim kit, Diablo Tuner, AAC Interior LED Light conversion, AAC LED Fogs, Danko Chin Spoiler (Shaved 1.25"), Mopar iPod Interface.
    402 Motoring's Avatar
    402 Motoring is offline East Coast Wide Body Specialist!
    Oct 2005
    Jersey Shore
    You could either use a 255/45/20 or a 265/45/20
    We are the National Sales Leader on Grip Tuning Products.
    We will beat any advertised Price!
    1-877-254-6448
    We are also a UAS and BC Coil Over Dealer, if your looking to lower your LX, pm me for a great price!
    Check us out at:
    www.402Motoring.com
    www.Shop402Motoring.com
    On FaceBook
    On YouTube
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Quote Originally Posted by 402 Motoring View Post
    Great! Thank you! Anyone know about the offset and any issues with inner wheel well rub or wheels sticking out past the fender? Like I said these have a 40mm offset and i'm just trying to work through my concerns.
    Magnesium Pearlcoat
    Digital Bobby's Avatar
    Digital Bobby is offline What Me Worry, You Worry!
    Apr 2008
    Mill Creek, WA
    I'm not sure about the offset difference but I've got a pair of OEM 20's off my RT for sale if they fit. Haven't made a price yet...
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Quote Originally Posted by magnumitis View Post
    Is your R/T an All Wheel Drive? I know the offsets are different between the two. Sweet wheels!
    Magnesium Pearlcoat
    Token's Avatar
    Token is offline First AWD LX in the 12's N/A
    Center of the LX Universe
    Your 20X8.5 with 40mm offset should be just fine with 402's suggested wheel sizes.
    Just make sure that the bolt pattern is 5X115 for correct fitment.
    Also the 20"s from a RWD R/T will not work for you. Nothing against magnumitis but those will stick out too far, and even though they look good in the pic the OEM wheels are steel clad with plastic chrome...... Not so good :(
    12.645@108.18
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Quote Originally Posted by Token View Post
    Cool.. I was pretty shure that the RWD R/T wheels were'nt going to work. I remember reading about that, but good to know its a definate no. Thanks for the info! Now all i gotta do is come up with the cash
    Magnesium Pearlcoat
    whelin's Avatar
    whelin is offline HalfFast FTW!!
    Nov 2006
    Brantford, ON. Canada
    What he said. Also, make sure the wheels are hubcentric or get them to ship hub rings with the wheels.
    RIP Dave. Missed, but, not forgotten.
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Ok maybe I need that one explained to me a little. Hubcentric and hub rings?
    Quote Originally Posted by whelin View Post
    Magnesium Pearlcoat
    Oct 2005
    Jersey Shore
    A hub centric wheel is one the is made specifically for your car. It fits tight over the hub. The hubs on the LX platform are 71.5mm. Most aftermarket wheels are not hub centric. They are designed to fit many different cars, so the manfacturer the wheel with a larger center bore. What this means is that you will need a ring, generally made of plastic, that will take up that extra room. As an example alot of AM wheels have an 80mm center bore. If you were going to put this wheel on an LX you would need to get a hub ring that would go from 80mm down to 71.5. As a LX experienced wheel dealer we would make sure you got the rings with your purchase, but it is not automatic at many wheel shops, you may have to ask for them.
    1-877-254-6448
    Check us out at:
    www.402Motoring.com
    On FaceBook
    On YouTube
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Awesome! Makes sense to me now. So the rings just make sure the wheels stay centered on the hub. Easy enough to understand. Thanks for your help!
    Magnesium Pearlcoat
    LowGo's Avatar
    LowGo is offline Alter ego of MyMaggieMae...
    May 2005
    Gresham OR
    Quote Originally Posted by mac424 View Post
    I learned about these the hard way a couple years ago. I would never get a custom wheels again without them. Lug bolts aren't made to accurately center a wheel. In case it helps... here's a picture of what they look like.
    Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?!
    German influenced garage queen .................... German engineered daily driver
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Well you know what they say. A picture is worth a thousand words. Thank you for that! I checked on the wheels I was looking at and they do come with rings so I should be to go on that front.
    Now as long as the 40mm offset works out then I should be good. Now I just gotta save some pennies.
    Quote Originally Posted by LowGo View Post
    Magnesium Pearlcoat
    LowGo's Avatar
    May 2005
    Gresham OR
    You should be fine with a +40mm offset. I have +42 or +45mm (I can't remember which) on mine with 255/45-20 tires and I'm able to drop the car with no problems.
