my 2007 RT, AWD Magnum steering has developed a creek when I turn the wheel?I have replaced the drag link and tie rods a while back 30k or so ,thoughts?
This sounds familiar to me. Do you hear it just once per rotation? That's when I get mine (curious if we've the same problem).
Warning: The above post probably contains 2 or 3 times as many words as necessary.
2005 SXT AWD. Purchased in March of 2009. Totaled on January 16th, 2013. 75k excellent miles together.
1982 Isuzu I-Mark Diesel. Haphazardly acquired January 2010.
1981 Honda Twinstar. Salvaged from my backyard in 2009.
2006 Volvo S60R. Acquired Feb 1st, 2012.
1966 Ford F100. Acquired March 30th, 2012.
kinda when I turn .. sounds like ball joints but no free play???
if it's tight enough to creak, there will be no free play. use a stethoscope to locate the creak while an assistant turns the wheel.
I had this problem on my '05 MRT/AWD.
Only way it ever got remedied was using a needle injector on the ball joints, refillin' with grease.
Not the 'right' way but it worked for a couple seasons.
It's hard to be humble when you're from Painesville, Ohio.
2003 Mercury Marauder - #420 of 7839, built with pride at St. Thomas Assembly.
2004 Mercury Grand Marquis LS Limited - one of 87583, which one? Idunno.
2005 Dodge Magnum R/T (2D8GZ58265H537094)...SOLD May 2011 w/106k showing. Lemon party.
