Results 1 to 9 of 9
    PAChargerR/T's Avatar
    PAChargerR/T is offline LX Newbie
    Coatesville, PA
    AWD Staggered? Anybody tried it????
    Did a search and found only one comment that it will "mess up the driveline after time". Has anyone done this? If so wheels sizes, pics, and some offset numbers. I would assume the higher offset would go to the rear? I just can't seem to understand why it would damage the driveline.
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by PAChargerR/T View Post
    Do you want staggered heights between front and back or stagered width fron to back?
    Coatesville, PA
    Sorry I should be more specific.......staggered width only
    done's Avatar
    Old Hickory, TN
    That would be no problem. Just kep the tire diameter as close as you can fron to back.
    spinnercj8's Avatar
    spinnercj8 is offline Up for a new Challenge
    Jun 2006
    Greenfield IN
    Staggered width will work as long as the height stays the same, if not your front and rear tires will be turning at different speeds which will detonate the AWD over a short period of time!! I have seen guys run 33in tires on the front and 35in on the back of Jeeps and cant figure out why the transfer case goes BOOM!!
    artist rendering by StitchMonkey
    LxReJx We have two Rules
    "Love Cars and Have Fun"
    UPS92008's Avatar
    UPS92008 is offline appetite for destruction
    Sep 2007
    Carlsbad CA
    I would image looking at subaru or audi would steer you in the right direction. If they are doing it then it can be done safely. I think it would be hard to find staggered tire sizes that have the same diameter.
    It'll be cool as hell if ya can pull it off.
    20" Vipers/ Afe Stage 2 Pro Dry S/ BT bling/
    Stealth lights/ mopar/ KILLERGLASS
    CORSA/ EBC USR's/ HOTCHKIS/ Diablosport/
    HID 5000K/ BMC/ jj's precision guesswork/ MGP/
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by spinnercj8 View Post
    Quote Originally Posted by UPS92008 View Post
    Those vehicles use a different type of transfer case. Ours also works as if it were a center differential as well as a torque splitter. A small amount of tire height difference would not be a problem.
    Here is a description of how it works.
    The Transfer Case - how it works
    Coatesville, PA
    Thanks for the good info. I have not really checked wheels with the proper AWD offset in the staggered width category, it is hard enough to find just regular wheels for AWD. I would think a really high offset (+55mm) for the rear with a 20x10.5" wheel and the normal (35-44mm) offset for the front with a 20x8.5" wheel. Also the tire height would stay the same front and back, just the width difference. I think that would be easy to find tire sizes, or am I wrong?
    Isnt there a wheel caculator on the net somewhere?
    HemiHearse's Avatar
    HemiHearse is offline LX Padiwan
    Mar 2008
    Hills of TN
    Try this one. It come up w/ "standard" and "side". Click on "end".
    We used this to put tires on my old chebby truck. 245/60-15s on the front and 295/50-15s on the rear.
    http://www.miata.net/garage/tirecalc.html
    GONE: 05 RT AWD Black/Tan Leather/SiriusNav
    Production Date: Pearl Harbor Day '04
    Mods: Auto Headlights, CAI w/ Ram Air Mod, Glasspak Reso's, Partial DeBadge, Matching Tint, AF Nav Hack, 4127 T-Stat.
    Hemi Registry #894
    My other rides:
    96 Beretta - 35mpg all day every day
    91 Cavalier Convertible RS - Mint Garage Queen
    79 CJ- 5 Woods Runner (beatermobile)
