Results 1 to 15 of 15
    done's Avatar
    done is online now Member for 7 years
    Old Hickory, TN
    AWD Shudder repaired
    In the last couple of weeks my car had been exhibiting the shudder from the transfer case at low speeds and high turn angles. So last Thursday I dropped my car off at Music City Dodge here in Nashville.
    I asked them if they minded if I suggested a TSB and they said "That would be fine, we get them all the time form our customers. Everbody is on the internet these days" Obviously this is starting out well. Then they asked if I needed a rental car as the service would not be done that day. They checked to see if I was entitled. I have the extended service agreement, so I was. Good again.
    I picked the car up on Tuesday and the TSB repair was done. They never made any mention of the obvious mods on my car and were professional, freindly and efficient.
    A very satisfying experience indeed.
    05rtawd is offline LX Newbie
    Raleigh, NC
    What was the TSB #? My 05 RT AWD sounds like it has the same problem. It is most noticeable when I am backing up and turning (to get out of the driveway or a parking spot).
    I bought it with a warranty from Carmax a few months ago, so hopefully it will be covered by them.
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by 05rtawd View Post
    TSB 21-011-06
    Good luck, Is your car still under the original drivetrain warranty?
    Raleigh, NC
    Thanks - I am taking it in today and will ask them to consider that TSB.
    I'm the 2nd owner and have had it for a few months now with 40k on the clock, so I'm not sure what kind of warranty it still has. I did get the 5yr 60k mile warranty from Carmax when I bought it used.
    Hopefully this will clear it up, and maybe get rid of the slight highway shudder I'm getting as well.
    Thanks!
    fnkychkn's Avatar
    greasy cardboard box
    Thanks!
    TSB 21-011-06 will not repair a highway shudder, but TSB 21-003-06 might.
    Raleigh, NC
    Thanks for the tip on the highway shudder TSB. I don't think I have that one, since what I meant was more of a bouncy/vibration feeling at certain speeds. My transmission is definitely old enough to be hit by that though.
    I took it in and they had one of their techs take a ride with me and he thinks the highway speed vibration is just an unbalanced tire. I couldn't get the car to do the slow-speed-sharp-turn grinding/shuddering noise since it was warmed up, but explained what it is like from a cold-start and showed him the TSB 21-011-06 and he agreed that was probably it.
    They had to order the part needed, and next thursday I'll drop the car off so they can do the work. He's going to call Carmax & make sure they cover it since it is a fix for a failed part. Pretty nice folks.
    Raleigh, NC
    The TSB fixed my slow-speed-turning shudder problem. Turns nice & quiet now. Thanks for all the info.
    AWD_Guy's Avatar
    AWD_Guy is offline Bringin the tech
    Sep 2007
    Buckhannon, WV
    Just made an apointment to get the shudder fixed on my 05'. I tried to get them to go ahead and order the parts they'll need to do the TSB, but all I got was a "all it needs is a tranny flush" response.....which worries me. The local dodge garage is worthless and this place is an hour away and supposed to be much better. I don't really want to make two trips up there but I guess I'll have to play their little poke and hope game untill they believe me.
    I'll just leave a copy of the TSB on the seat and hopefully they'll see the light.
    Can anyone confirm that the transfer case fluid is seperate from the tranny fluid? If so that should at least cut down on the $$ spent as I'm sure the 7/70K warrantee won't cover a fluid change.
    LouZ's Avatar
    LouZ is offline LX Guru
    Dec 2004
    NY in the mountains
    Quote Originally Posted by AWD_Guy View Post
    The transfer case fluid is seperate form the trans fluid....
    Lou -05 Magnum RT AWD ---> FRI'd 392
    LowGo's Avatar
    LowGo is offline Alter ego of MyMaggieMae...
    May 2005
    Gresham OR
    I just made an appointment to take mine in tomorrow. They too want to look at it before ordering any parts. Fortunately, they're only a couple miles away, so repeat visits isn't an issue. I did talk with them about the known shudder issue on the AWD, and the service writer did agree that it was probably the issue. He does know that my car has been lowered, and did mention that, but also admitted that it will only be an issue if it can be show to contribute to the problem. Hopefully, it won't be an issue.
    Good luck with your repairs.
    Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?!
    German influenced garage queen .................... German engineered daily driver
    done's Avatar
    Old Hickory, TN
    It is not unreasonable for them to want to see and drive the car first. This is actualy a pretty expensive warranty job and they need to make sure they are right when they order parts. When I had mine done, I had to leave the car over the weekend. Fortunately, I have the Chrysler service contract so a rental car was covered.
    Scott is offline AWD Fan
    Dec 2004
    Wisconsin
    My car was one of the first to get the shudder problem. The dealer replaced the transfer case fluid with a fluid having slightly different friction modifers. They/we didn't know what the cause of the problem was at that point. Anyway, the symptoms went away for 4-7k miles or so.
    Later when the symptoms returned, Chrysler then knew what the problem was and had issued a TSB.
    The TSB is not likely something the dealer can just squeeze-in the same day if they were only planning a fluid change.
    I don't think we know if *all* 2005's get the symptoms, so letting them try the fluid change, seems reasonable.
    Chrisjh is offline ChrisHackett
    Feb 2006
    I had the driveline shudder problem and the dealer fixed it on the same day along with other service (drop off car in AM, pick up in PM). Clutch thingy, vent tube, and fluid replace.
    2005 Cool Vanilla MRT/AWD
    Borla 112, K&N Polished Typhoon intake (music!)
    Superchips Flashpaq (91/sport)
    GoldenEye 6K HID (with relay kit)
    245/55/18 BFG KDWS (HUGE improvement)
    Hemi-Tick enabled (best heard when cold)
    4127 thermostat
    NGK V plugs
    Hawk HPS front pads
    Had a '95 Impala SS
    JamminWagon's Avatar
    Cheyenne, WY
    Sounds like you have a winner of a dealer!! Mine here said that the passenger airbag sensor was caused because the car was getting a MIL/CEL message of missing radio. When I told them that I have had the problem before because of moving and putting a TV on the seat for 500 miles, the only way to get them to do the seat procedure was to say " I will pay for it if it dont fix it". When I picked the car up and it did fix it, the service writer had to go on lunch all of a sudden.
    You need to write the manager and express your postive experience.
    AWD_Guy's Avatar
    Sep 2007
    Buckhannon, WV
    Got the car back a few days ago, shudder is fixed. The tech also re-attached the exahust using an "alternate methode" that was supposed to reduce some droning issues. This caused the exhaust to rattle on the crossmember. He ended up having to put some washers under the crossmember to get it to clear. Is anyone aware of this "alternate method" and can I undue it? The exhaust cleared fine before he messes with it.
