Thanks for the welcome and tell me about your recent exploits with your machine. When you ran your 13.1" what tires and wheels were you using? I've found that a 25" diameter works just right for the power I have now. 6,600 rpm just gets me across the line in 3rd. Have you monitored any 1/4 mile runs with your Predator. How much timing do you have on cylinder #1 through the rpm range? I am real happy with the 33 degrees at 6,600 rpms for my shift, although it is a little tricky, especially in 1st gear to stay under the rev limiter. What are your shift points? Have you been able to get your 300 to autokick beyond 6,200 rpm? I can't. Can you get more than 6,600 in manual? I can't. Do you have a wide band sniffer now? How is your AFR at 2-10 percent throttle and 1,500 rpm? How much wheel spin do you have at launch? If you've had any, what have been the side effects?
Anyway, good to hear from you again and to hear that your machine is back together. Now spill the beans on the paticulars...
