Results 1 to 9 of 9
Thread: AWD Dyno Fun
    LouZ's Avatar
    LouZ is offline LX Guru
    Dec 2004
    NY in the mountains
    AWD Dyno Fun
    Well , I tried to get a tune from Promotion...........NOT.......
    Not their fault whatsoever......car would not cooperate........
    First thing we noticed was the front axel spun at half the rate as the rear????????
    We did the no espmod.....remove fuse 17.....disable esp thru diablo and various combos of the above.......
    The car went into limp mode and would not rev above 3000 RPM....
    We tried the jeep trick where you put in 2nd and nail it........
    That didn't produce limp mode but the the dyno was like WTF???? and would not register......
    At higher RPM(we went up to 109 MPH) the axels seemed to catch up......
    but the dyno was not happy.....
    I've got a few mods planned and gona "street tune" this thing......hope that's not gona be to expensive.......
    Lou -05 Magnum RT AWD ---> FRI'd 392
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Lou,the dyno we have up here links the front and rear rollers so that won't happen.I am sure Dave can do emails with your datalogs from there.
    BFNY PERFORMANCE
    RIP My Friend
    LouZ's Avatar
    Dec 2004
    NY in the mountains
    Info........or PM me....I still gona do some mods before my next tune session......
    MAGNASAURUS is offline LX Padiwan
    Jul 2007
    Fredericksburg, VA
    Quote Originally Posted by LouZ View Post
    My car did the same thing at Promotion. It did crank out 138 hp at 3000 rpm's though!
    2005 Inferno red AWD RT
    2002 Collector Edition Trans Am(F-bodyhideout member)
    done's Avatar
    done is online now Member for 7 years
    Old Hickory, TN
    I think the result is logical. The torque split form front to back is about 1 to 2. Thus, if the dyno puts the same resistance on both the front and rear rollers, then the rear wheels ought to turn at twice the speed, due to twice the torque.
    I would hope that the AWD dyno has some way of adjusting the load ratio front to rear to accomodate our cars instead of assuming that all AWD/4WD vehicles are always split 50/50 on torque.
    madeulooq's Avatar
    madeulooq is offline LX Guru
    JERSEY/VA
    Oh this sucks, I was planning on hitting the promotion dyno for a tune after me H&C install in January.
    Hey Erik what dyno are you referring to?
    MODS..AFE II, DIABLO PREDATOR,SRT EXHAUST,INERTIA HEADS AND SPARTAN CAM(BOB@SVS TUNED)
    >>>>>>THIS IS SPARTA<<<<<
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    That sounds like a 100% dyno machine issue. It should have a way to lock the front and rear wheels together, or a way to adjust the load on each axle so the wheels all stay at the same RPM.
    Hemi31's Avatar
    Quote Originally Posted by madeulooq View Post
    It's a Mustang that can lock the front and rear rollers together.
    BFNY PERFORMANCE
    RIP My Friend
    ProMotionTuning is offline LX Padiwan
    Fredericksburg, Va
    Quote Originally Posted by lafrad View Post
    You are unable to do this on a DynoJet Machine... The car would need to be tuned on a Dyno Dynamics or Mustang Dyno.
    Pro-Motion Tuning, LLC
    Authorized DiabloSport CMR Tuner
    ProMotionTuning.Com
    Fredericksburg, VA - 1.877.724.6682
