Results 1 to 14 of 14
    semihemi2's Avatar
    semihemi2 is offline DIRECT CONNECTION
    Bentleyville, PA
    Will not come out of Park
    My 05 Magnum sometimes will not come out of Park. Has any had this same issue?
    http://i91.photobucket.com/albums/k2...6/DSC00149.jpg
    http://i91.photobucket.com/albums/k2...6/DSC00153.jpg
    http://i91.photobucket.com/albums/k2...6/rtside07.jpg
    K&N Air Charger Intake, Dynomax Dual Exhaust, Factor One Garage led tail lights, Rock Blocker eyelids, 22elite leather console & door arm rests, Chrysler 300 Machined Aluminum Wheels.
    STAGE 3 R/T's Avatar
    Jan 2006
    Argyle, Tx
    hmmm you pressing on the brake pretty good? no ideas here...
    semihemi2's Avatar
    Bentleyville, PA
    Yes, I pressed the brake. When i rock the car a little it will release.
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    sounds like a faulty switch on the tranny/brake...probably worth taking to the dealer.
    Bruce Maichle's Avatar
    Bruce Maichle is offline Supporting Vendor
    Jun 2006
    Wilmington,De.
    Defonate shift interlock cable problem.Make sure when this is happening that the brake lights are working.If they are then it may be a bad solonoid on the interlock cable.
    The Leader In LX Performance Parts & Installation
    Check Us Out Online & Contact Us Today At 1-888-894-1115
    My Street Cred: HHP Shop Manager & Chrysler Certified HEMI Specialist with vast experience with Heavily Modified LX Vehicles.
    DonH's Avatar
    DonH is offline Enough and no waste is good as a feast.
    Jacksonville Fl
    Have you tried the manual override release button to the right of the shifter under the rubber pocket thing? Mine has this and I assume all the LX have them, but I could be wrong.
    BobF's 6POINT1's Avatar
    May 2004
    PHXAZ
    There is also another pink switch under the shifter (on the 5 speeds at least) that you may need to check as well by taking apart the trim on the console. There is a known problem with a plastic shifter spring clip breaking. This usually happens all at once instead of intermittently though.
    doughboy's Avatar
    doughboy is offline Me no speakie engrish?!??
    Jan 2007
    South Floreeeeda
    Had it happen to me not too terribly long ago, I made a post about it with the part numbers and approximate price. Mine was under warranty so no big deal for me there...I'll see if I can find it for you...
    Edited to add:
    shifter problems and fix
    That thread is all about it.
    Quote Originally Posted by doughboy View Post
    Lol. This JUST happened to my shifter assembly. Luckily under warranty. So no major issues, other than having to way almost a day or something for the right part to show up.
    Edited to add:
    Just for anybody that decides to do this out of warranty at a dealer. Not certain how many hours or the hourly rate for the labor.
    Description List Price - Unit Price Labor
    4578029A SHIFT ASM 54.85 54.85 179.50
    Parts and Labor total: 234.35
    Theres part number and price.
    06 Charger SRT - Smashed into by a semi trailer :(
    05 Magnum SXT - Great for hauling the kids around in...but now I want some more stuff on it...
    08 Charger RT - 13 miles on it after the test drive
    semihemi2's Avatar
    Bentleyville, PA
    Thanks for all the input. I am going to take it to the dealer next week. Just got it back from a $2400 deer smack on friday. should have had them look at then.
    doughboy's Avatar
    Jan 2007
    South Floreeeeda
    Quote Originally Posted by semihemi2 View Post
    Damn thats some expensive Venison....
    Hopefully you wont have the hassle that I had. They got the right part, but the wrong shift cable or some garbage so it took them an extra like three hours waiting for the right part. Mind you that could well have been the service manager BS'ing me because they forgot to order the part in the morning...
    impala11419 is offline LX Padiwan
    Brooklyn, NY
    when you rock it do you hear a clunk when it comes out. Also do you park it on a hill?? If so then that is normal. I had the same problem when i first got my 300 and the manual says that theres a locking mechanism that locks the shifter and you have to rock it. So what I do now is before I put it in park is drop the park break and the regular break at the same time. Then i put the shifter in the N position and release the regular brake. The car moves a bit then i put it in park. That might be ur issue.
    Hope this helps
    cosmok is offline LX Newbie
    Dec 2007
    There was a recall for '05 for that problem. The dealer will fix it.
    SilvaSurfer's Avatar
    SilvaSurfer is offline SRT-8 Driver
    SoCal
    keep us posted on the fix and good luck.
    Jay
    Matthew 7 ver.17 Even so every good tree bringeth forth good fruit; but a corrupt tree bringeth forth evil fruit.
    Formerly Known as dntnvme
    semihemi2's Avatar
    Bentleyville, PA
    sorry
    Sorry for the late post. I took it back four times. They can't find anything wrong with it of course. I'm going to take it to a different dealer. For now i just been pushing the pink button to release it. i will keep posting.
