Results 1 to 7 of 7
    bellman3021 is offline LX Newbie
    Sep 2009
    Wierd engine temp problem
    Really strange problem. I have a 2006 sxt with cold air intake and I'm using the 89 oct predator tune. My engine temp gauage needle will run just under the middle line when idle or stopped. If I drive on the highway it falls to just above the first line. The heater is throwing off hot air though. I plugged the predator in and the ect temps
    during highway driving are hovering at 128.
    The theromstat and temp sensor were just replaced with the same results. The air temperture round here has been in the high 20's. Eventually the P0128 error gets tripped. I also notice when the car downshifts at wot a puff of brown smoke blows out the back. I don't baby the car can't imagine I'm gettng this much carbon build up... I'm lost at this point and don't know what to try???
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    you didn't put teflon tape on the sensor threads did you?
    I don't have the manual in front of me but I would find the spec for the ohm reading across the pins on the sensor and test that and then trace your wiring and look and see if anyone was chewing on it.
    BFNY PERFORMANCE
    RIP My Friend
    Zombifyd's Avatar
    Zombifyd is offline LX Padiwan
    Nov 2007
    Long Island
    I get the same thing when winter hits here my temp gauge drops to bottom line and the CEL comes on with that code, and then I loose heat. I heard it has something to do with the thermostat, that you need a higher temp one. I still have yet to look deeper into the problem.
    http://www.lxforums.com/board/signat...pic15199_1.gif
    2006 Magnesium Pearl Magnum SXT
    *2009 Challenger RT rims*Custom Wooden Shifter*Hood lift struts*Strut tower caps* Big Bully Intake*Carbon Fiber Engine Cover*BA speaker system*
    Toronto Charger's Avatar
    Toronto Charger is offline Charger Zealot...
    May 2009
    North York
    Get it checked out at the dealership for warranty work! Reverse your Pred mod first... there was another thread where a guy had it run too hot for too long due to his fan failing and they voided the engine warranty for neglect... let 'em have a peek but be clear that you don't wanna pay if warranty will not cover it.
    Better safe than sorry...
    CAI, R/T Dual Exhaust, Predator 91 Octane Tune, De-Badged, Charger Badge on dash, R/T Flat Black Grill, Charger Script on Grill, R/T Fog Lights, Mopar Locking Gas Cap, Candy Apple Blue ghosted stripes front to back
    Mics Mag's Avatar
    Mics Mag is offline LX Padiwan
    Mar 2009
    Windsor ON CAN
    Hmmm, hope its not a head gasket leak. Is your coolant level going down? You can have a pressure test done on the system to check.
    07 STEEL BLUE MAGNUM SXT, JBA Headers, RT Exhaust w Magnaflow X, Predator tuner, BT Catch Can, Mopar CAI, Tinted, Cabin Filter, Curt 2" hitch recvr, Pro Series 48x32 Cargo Carrier with Bi-fold ramp, Munroe Air Shocks, Krown rust protection, debadged w SXT/6, Chally 18" alum rims, 225/60s.(winter) 235/55/17 staggered 215/60/17 (summer).
    ToddStone's Avatar
    ToddStone is offline Bug Killer Extreme!
    Spokane, WA
    Did you try to reset the tune to it's natural state and then retune it? That might be the issue and then pull Fuse 11 on the fuse box. See if that works.
    Mods: Big Bully/Spectre Cold Air Intake; R/T Exhaust;JDM Headlights; SRT Sways; Tinted Windows;Boston Accoustic Speakers and 10" sub, Crunch 500 watt power amp; KW V1 Suspension/Coilovers; Predator Tune; Fog Lights; 71mm TB and lower intake; HoneyComb grille; JBA Headers.
    Clayman's Avatar
    Clayman is offline LX Padiwan
    Nov 2007
    Winnipeg, Manitoba Canada
    This is common here up in Canada, and mine does the same thing, I don't drive in the wnter so I don't care. But it is your thmerostat is sticking open, I change lots to t-stats for this problem.
    ModernMuscle Supercharger 11.5psi, Procharger HO intercooler, Tail 50mm BOV, JBA shorty hedders, Ported T-body, Ported Lower intake, Getrag LSD 3.73, Predator Tuner, Zommers cat back with x-over, lowerd 1.5" and rolling on 255/45/20"s, Dyno numbers 305rwhp 275ftlbs and 13.25 at 106.11mph in the 1/4.
