inching up on 100k miles, and looking at replacing the 3.5L timing belt "just because." The service manual says that I need to pull the valve covers and loosen the rocker arm ass'ys....
Are you kidding me?Is this really necessary or only if you're pulling the gears as well? The SM isn't clear on that issue, as they lumped the belt and sprockets together in the same section.
Anyone want to elaborate? TIA.
Here's to another 100k I guess!
and work on the GP, too!
