Results 1 to 5 of 5
Thread: Timing Belt
    karfreek's Avatar
    karfreek is offline LX Guru
    May 2006
    Fultonville NY (Upstate)
    Timing Belt
    Is the 3.5L an interference engine? IE: if the timing belt goes do you risk taking out valves? My wifes Pacifica has the 3.5L in it.
    Jay
    2011 Dodge Challenger R/T Classic - Redline 3-Coat Pearl, 6-speed
    2005 Dodge Magnum RT-Can you say...HEMI?
    2004 Chrysler Pacifica AWD-Everything but the kitchen sink.
    MagNite is offline LX Guru
    Rochester,N.Y.
    Yes, it is. The service manual for our LX's says to change it at 105,000 miles, but I think I'm going to do mine soon. I'm almost at 80K. May as well do the water pump while it's apart also.
    tt_dexter is offline LX Newbie
    Western CO & NE MD
    Yes, it can get REAL expensive if you strip the belt. I went 120k mi. without problems on mine but I don't recommend it. Whether you do it yourself or have someone else do it, you should factor in a few other items when figuring cost.
    1. Timing Belt
    2. Water Pump
    3. Timing Belt tensioner pully kit
    4. Serpentine accessory belt and tensioner
    5. Antifreeze
    6. Upper and lower radiator hoses - mine seemed ok but I figured I was into it pretty deep at that point so, what the heck.
    If you elect to do it yourself there are a couple of helpful threads here and I'd be happy to let you know how it worked for me.
    mrriverajr is offline LX Newbie
    Sep 2009
    i gotta do mine too, is it easy?
    donatello79's Avatar
    donatello79 is offline ellis-mate fan
    Jan 2007
    Ephrata Washington
    I just did my 05 magnum with a friend of mine. Replaced timing belt, water pump, tensioner pulley, upper and lower radiator hose. Total time if you take the beer drinking and screwing around out of the equation was probably 4 hours. I did not take the valve covers off or remove rocker arm assembly like the manual said. I pulled the fan assembly out, then went to town. The key thing you need is the right puller to pull the crankshaft pulley, and a longer bolt for that pulley to suck down the pulley back on to the crank. I had 114k on my car. One other thing. If you can, lube the pulley that is on the timing cover. Mine was in desperate need.
