Well the second set of results are in. K&N filter.... = GOOD.
Theres many types of dynos out there. not all numbers can be compared with other numbers just out front. mustang dynos are usually higher than dynojets, load dynos usually dyno the lowest, but results are like hydraulic dynos which are extremely accurate in detecting change, but tend to be 16% lower than dynojet and dynapacks. dynapacks and loading dynos are usually more accurate due to to smaller or non existence of any kind of roller that can create a variable from the inertia of the roller. if you dont have a roller to begin with, then thats one less variable to factor in (tire slippage, tire pressure, strapping tightness of the "oh shhhhh---T!" straps that keep the car from jumpin off) both mid atlantic motorsports and agile auto used to be closer, but agile auto moved about 20-30 miles north of where they were. and mid atlantic was only about 12 out of their old location. plus i know the guys more who do the tuning for the drift team Drift Alliance in the Formula Drift competitions. so for now its Mid-Atlantic for me.
This time i used their newest dyno to the shop which is produced by Dyno Dynamics out of Austrailia. its more of a tuning dyno as opposed to some inertia dynos. Inertia dynos dont tend to pick up the smaller blips and surges throughout the entire rpm (very useful in tuning if you plan to tune throughout the rpms as accurately as possible...no point of having high max power if the rest of the powerband is choppy). its due to the size of the roller. remember the old physics law of kinetic energy....bodies in motion stay in motion until another force acts upon it... but the larger the part in motion, the more force it will take to alter the course. larger inertia rollers on dyno jets and mustang dynos dont pick up those smaller forces that when tuning a car, you will want to pick up for driveability issues. not just in tuning for WOT and max power results.
heres the low down on the setup and why i chose this route:
overall, i'll be getting tuning done there more than likely as long as they have time with the current drift season coming up....man, wait till you see some of the pics.... Vaughn Gitten Jr's drift alliance car....wrecked. theres some work to be done there before the season picks up.Why is a loading dyno (Dyno Dynamics) better than an inertia dyno (dynojet)? - Loading dynos are better than inertia dynos for a number of reasons.
***IMPORTANT FEATURE****
A) Steady State Tuning - Steady state tuning is the highlight of the loading dyno. Because the loading dyno uses an electric brake to keep the rollers from accelerating it is able to precisely vary how much load is placed on the cars engine. When the dyno exerts as much load on the engine as the engine is putting out, the rollers will stop accelerating and hold a constant speed. Because the engine is not accelerating we call this a steady state. During this time the dyno is measuring the load between the brake and the car and outputs a live power number. This is very useful for tuners because it allows them to make changes to each part of the ignition/fuel map and monitor the power gains or losses in real time. With an inertia dyno there is no way to keep the rollers from accelerating and therefore no way to hold a steady state. The engine simply accelerates through the ignition/fuel maps too quickly.
****MAIN SELLING POINT FOR ME*****
B) More precise measurement - Because inertia dynos use a heavy mass to simulate the inertia of the car being tested it is hard to monitor minor changes in power. The large mass of the rollers results in very minor changes in roller speed that inertia dyno sensors have a hard time picking up. If the sensor and computer don't see the change in roller speed the the dyno graph will not show a dip in power. However, a loading dyno uses rollers with very little mass and directly measures power rather than calculating it. Quick drops in power will be picked up by the load sensor and will show on the dyno graph. This is very useful for finding problems and ensuring that your engine is running correctly.
C) Load can be controlled - With an inertia dyno the load exerted on the engine as it accelerates is based on the inertia of the dyno rollers. This inertia is set by the mass of the rollers and is not able to be changed. The inertia of the dyno rollers directly determines how fast the cars engine will accelerate through each gear. Ideally this inertia would be equal to the inertia of the car being tested but this is rarely the case. The inertia is almost always going to be higher or lower than the inertia of the car and as a result the engine accelerates faster or slower than it would on the street. This can have a bearing on how the engine is tuned and how accurate the dyno replicates real life conditions. Because a loading dyno is able to actively alter the load on the rollers it is able to change the rate of acceleration as the operator pleases. Realistic loads for the particular vehicle can be used or loads simulating driving up a hill can be used. This is easily controlled by the dyno operator.
D) Problem Diagnosis - This feature goes back to the ability to control load and do steady state tuning. A loading dyno is able to simulate road conditions in a safe environment while allowing the technician to monitor the car and it's engine. An inertia dyno is unable to accurately simulate all but a few road conditions making it much more difficult to diagnose problems.
OK, back to the post. the numbers of this dyno in particular are about 16% (according to Mid Atlantic Motorsports & Dyno Dynamics in Austrailia) lower than dynojet results.
Bear with me as theres alot of info to post...as that dyno has many features i was trying to learn and take advantage of with their time schedule. and man is this thing accurate...you can literally pedal a mountain bike on it, and it picks up each time you pedal.(yes...boredom does set in and the only reason we know because it was done. Ray (operator) kicks out about 1.6HP btw...) inertia dynos are larger so they tend not to pick those small things up on the dyno. my first results were done on dynapacks, if unfamilair with that setup, check here: http://dynapack.com/dynapack.html the results to that was 172.8HP and 176.7TQ
Todays results were 148.6HP base line again. now remember the 16% lower difference. So on a dynojet would read 171.68HP roughly a 1 hp difference.
After a 3 minute switch to the K&N filter, i actually threw down a 152.4HP rating. with the 16% defeceit, 176.78HP. so roughly 5whp is to gain from simply switching to a K&N drop in filter.
39$ for 5 whp. you dont have to be a whiz kid to recognize the HP per $ ratio is 1HP per 8$ roughly
Now heres all the sheets air fuel included:
so now that that part is out of the way, heres some of the pics:
Why sit around and watch everyone else live YOUR dream? Plus how many 330lb Samoans do you see doing standing dropkicks?
...the next
. you used a larger inertia roller if i remember right as well. one thing any dyno operator in the world will also conclude on is that some dynos are more accurate for tuning, others are more accurate for getting numbers, and there are many in between.
it showed a gain here, so with the difference on a dynojet that i've used. i just did the math. like said, the filter makes gains. granted it flows more air, which is at the cost of less filtration over a stock paper filter. it does the job and gets results.
And the dead shall walk
