So its been a while since my last dyno pull and in hopes of reaching some personal hp/yq goals I needed some more recent numbers.
Baseline Numbers (CAI, exhaust):
174rwhp, 195rwtq
Performance Mods from Dyno Test Performed 3/11/2009:
Inertia V1.1 Cams
CNC ported/polished Throttle Body - beta tester from BT(front side only)
Ported/Polished lower intake manifold
Airhammer HO Intake
Blastin Bobs 10db dual conversion (replaced suitcase w/ Dynomax muffler)
Custom tuning by Mike Lafrad
89 octane pump gas
Performance Mods from Dyno Test Performed 1/11/2010:
Inertia V1.1 Cams
Hand ported/polished Throttle Body - Front & backside
Airhammer HO Intake
Custom tuning by Johan
JBA Shorties, Ceramic Coated
Jet-Hot Coated Valve Covers
89 octane pump gas
The Dyno Sheets: (Red lines are run from 3/11/2009, Blue Lines are from 1/11/2010)
Horsepower / Torque:
Horsepower / AFR:
Torque / AFR:
Outcome, Discrepancies, Perceptions, & Driveability:
The previous run in red was was done with the motor at about 180* where as the new runs shown in blue were done at full heat soak (not sure of the exact temp). Towards the end we let the car cool for about 15min and did one last pull and got about 10hp and 10tq increase over the previous runs. Unfortunately the shop was closing and he had already printed everything out for me thats shown here and its not of huge concern to me.
These runs were done on a dyno dynamics dynometer which are known to be very conservative but very accurate because they take into account vehicle weight among other things into the correction factors so your numbers are very close to what you put down on the street - not just on rollers. The car was at full weight, 3/4 of a tank of gas, spare tire and rear floor, full interior trim, etc.
So what was the outcome... well, the car made more power earlier in the powerband for both horsepower and torque but lost a bit in the top end. It made an exceptional amount more low end torque and probably about 10hp! The tuners at Dynocomp suggested this was probably because of the car coming into open loop sooner. Not really sure why it lost power in the top end but some of the guys at the shop thought they heard knock right in the range where that drop occurs...and that 4500rpm mark is the magical "short runner" change for the plenum. The guys at dynocomp also mention the rev limiter appears to have been raised a bit from the previous run as well so that may impact things.
Changes in driveability... well the car produces more power where it counts and that makes me smile. Its more predictable, you dont have the knock sensors pulling timing left and right from false knock in the low end so acceleration is smoother. The car still bogs occassionally and I blame heat soak.
I plan to relocate my IAT down at the end of the airfilter near fresh air. I also will be installing jet-hot coated timing covers to match the valve covers (mainly for cosmetic reasons). The big mod coming shortly is stock-valve Inertia CNC Cylinder Heads. The dyno numbers will be posted on my SpringFest show board...
