Results 1 to 15 of 16
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    Are RT and SRT8 Cats Bigger then 3.5?
    I know a lot of the hemi guys have replaced their stock CCs with aftermarket high flow converters. This might be a good mod for our V6s if the stock hemi cats are bigger than ours and will bolt up. Anyone thought of this before?
    shadowvox01's Avatar
    shadowvox01 is offline Stand-Up Philosopher
    Jun 2007
    Cincinnati, OH
    I have a set of Hemi cats do install when I do my manifold retrofit project.
    The inlets for the converters are LARGE
    Tom Romans
    2004 Chrysler "SRTDesign" 300M Special
    Stage 3 Mods: 14.627 @ 91.98 (11/23/2008)
    It is alive......!!
    DannyC's Avatar
    Nov 2006
    Lynchburg, VA
    Let us know how much trouble it is. I'm pretty sure the mid pipe on a hemi is larger than our V6 but should be easy to fix that. Maybe run the stock hemi cats and mid pipe and then a set of FM with inlet the right size and outlet the stock V6 size so everything else works together.
    Magnum375 Jr's Avatar
    Magnum375 Jr is offline First NA 3.5 in the 14's
    Dec 2006
    PA
    Well, there are universal Magnaflow high flow cats, the only place i know that sells them are A&A auto parts, and I think they are 2.5 in/out diameter.
    RIP Maggie - (Aug 07, 2007 - Dec 04, 2011)
    ekaz is offline all gone
    Jun 2006
    CHICAGO
    The stock exhaust size on an SRT is 2.75, so should be doable.
    Unlawful Gathering
    Click for details!
    2009 MBP GCSRT8
    Powered by PWR
    Shifted by SHR
    Tooned by Johan
    Blinged by Billet Technologies
    MooNDoGGie's Avatar
    MooNDoGGie is offline Absent From Malaise
    Cambridge, Ontario
    As I understand it, the hemi CC's are exactly the same as our 3.5L CC's.
    ____°º©Mo0NDoGGie©º°
    PERFORMANCE MODs: kw coilovers,zoomers exhaust,jba shortie headers,diablo predator,hammer h.o.CAI,power slot rotors,hawk pads
    COSMETIC MODS: 20" zinik's,msrt8 front fascia,colour matched fog light bezels & rear wing,shaved front badge,6000k HID headlights & foglights,shaved & debadged,tinted FOG tail lights
    INTERIOR MODS: nav radio,msrt8 kicker sub-woofer,T-handle shifter knob & leather boot,BT aluminum dash knobs
    Samoan Tsunami is offline LX Padiwan
    Jul 2007
    Tofiga Island
    Quote Originally Posted by DannyC View Post
    just a question, but outside of extra weight from a larger part, what exactly are you looking to gain?
    the catalytic converter installed in stock form, will be rated for most all the mods boltons and mild internals will allow. thats just the way parts are made.
    aftermarket stuff is usually lighter.
    would seem to be more beneficial to follow suit and upgrade to something lighter than something used and heavier, with no performance advantage....
    if i am missing something, please let me know. i'm new to this forum, but i am not seeing the reason to use them...
    NC-SXT's Avatar
    NC-SXT is online now purveyor of fine custom grilles
    NC Coast
    Quote Originally Posted by MooNDoGGie View Post
    Different part numbers. The 3.5 and 2.7 are the same . 5.7 and 6.1 are also 2 different part numbers
    WWW.DodgeMagnumGrille.com
    Hemi RT's Avatar
    Hemi RT is offline ?????
    Jul 2007
    Medicine Hat, Alberta
    You have to remember that getting things to flow better is good up to a point. Unless you build your heads up to run with little or no back pressure you may run into a problem with a larger exhaust system. Also if it too free flowing you may throw codes.
    Your best bet is to get a system designed for your car.
    Hemi Registry #00730
    Jul 2007
    Tofiga Island
    Quote Originally Posted by Hemi RT View Post
    if you dont want to get a system for the car.... this article will help.... its written in conjunction with magnaflow, but gives the basics on building an exhaust. its been passed around through many forums.
    http://magnaflow.com/05news/magazine/05sportc.asp
    ZMagnum's Avatar
    Tucson, AZ
    There is no such thing as good back pressure on a 4 stroke engine. Each exhaust pulse produces negative pressure behind it. Just the opposite of back pressure. On a 2 stroke engine you need back pressure.
    Our engines are like a big air pump. The more air you can get in and out of it the better (as long as the air/fuel mix is good).
    MikeEast's Avatar
    Ducktown, Georgia
    It's all about flow, but it's also about the timing and velocity of that flow too, that's a pretty decent article.
    How else can I explain the 25 ftlbs of torque I gained on the dyno from going to a full Zoomers catback? My pipe diameter went down 1/4" in a few places, yet it performs better? Interesting concepts..
    Mike
    Jul 2007
    Tofiga Island
    Quote Originally Posted by MikeEast View Post
    Mike
    the velocity is a major "kine" with exhaust. many times people use too large of an exhaust pipe, thinking bigger is better, but they actually LOSE low end power. using an RT exhaust for looks would be fine, but if i am not mistaken, its still restrictive being stock...
    unless a car is highly modded, nitrous, boost, heavy N/A internals, i've personally never really seen the need for excessively large piping. maybe 1/4 inch more in pipe size, but when you take a single pipe and make two from there, sometimes you may have to go down a size (i.e. 2.5 single stock, broke down to a 2.25 dual aftermarket). thats just my experience. definately open to other experiences.
    DannyC's Avatar
    Nov 2006
    Lynchburg, VA
    I have duel exhaust on my SXT. I was just thinking that the RT or SRT cats may allow a little more flow if they are larger diameter but still able to bolt on.
    If the hemi guys are gaining HP with high flow cats maybe worth trying on our V6s.
    MikeEast's Avatar
    Ducktown, Georgia
    It's most certainly worth a try - if someone wants to come on over and get 'em, you can have my stock cats - they are just taking up space that I could use for storing other obscure stuff I don't need..
    Mike
