Well since there is a request for some pics I have provided some to show what I did.
Here is a shot of those slits that you want to cut into your adapters. This will the pipe to seal better. Just use a thin cut off disc. If you don't have experience with these discs PLEASE be care full and wear safety glasses and heavy gloves. These discs can explode and the shrapnel will take out teeth and eyes as well as sever tendons in your arms and hands.
This is a shot of the connection up front. The adapters fit over the lead pipe and inside the R/T exhaust for a leak free installation.
I tried pulling fuse 11 and didn't really find any difference. I do notice that at lower speeds if the car is in o.d. under 1500 rpm it has a tendency to gear down because of a slight loss in back pressure and bottom end. No real big deal and hardly noticeable. I like the way the car sounds and wouldn't change a thing. I do believe though this exhaust is about the limit for these motors. You can go louder if you want, but you may sacrifice what little back pressure is left.
"Whats been done once before won't hurt a second time!"
"If the rule you followed led you to this of what use was the rule?" Anton Chigurh
