P1005-MANIFOLD TUNING VALVE CONTROL PERFORMANCE
For a complete wiring diagram Refer to the Wiring Information
When Monitored:
With the engine run time above a calibrated value, battery voltage greater than 10.4 volts, ECT within a specific range, and the Manifold Tune Valve Assembly control active.
Set Condition:
This PCM compares the circuit feedback to a calibrated closed range when the circuit is de-energized or to a calibrated open range when the circuit is energized. If the value is determined to be out of the calibrated range in either the de-energized or energized state for more than a calibrated amount of time, this DTC will set.
Possible Causes
INTERMITTENT DTC
(K136) MTV CONTROL CIRCUIT SHORTED TO VOLTAGE
(K136) MTV CONTROL CIRCUIT SHORTED TO GROUND
(K136) MTV CONTROL CIRCUIT OPEN OR HIGH RESISTANCE
(Z816) GROUND CIRCUIT OPEN OR HIGH RESISTANCE
MANIFOLD TUNE VALVE ASSEMBLY
POWERTRAIN CONTROL MODULE (PCM)
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.(Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure)
1. DTC IS ACTIVE
1. Turn the ignition on.
2. With the scan tool, Clear DTCs in the Powertrain Control Module (PCM).
3. With the scan tool, actuate the MTV Solenoid Control State.
4. With the scan tool, select View DTCs.
Is the status Active for this DTC?
Yes
Go to 2
Refer to the *CHECKING FOR AN INTERMITTENT DTC Diagnostic Procedure.(Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure)
2. (K136) MTV CONTROL CIRCUIT SHORTED TO VOLTAGE
1. Turn the ignition off.
2. Disconnect the Manifold Tune Valve Assembly connector.
3. Disconnect the Powertrain Control Module (PCM) connector.
4. Turn the ignition on.
5. Measure the voltage of the (K136) MTV Control circuit in the Manifold Tune Valve Assembly harness connector.
Is there any voltage present?
Yes
Repair the (K136) MTV Control circuit for a short to voltage.
Perform the PCM Verification Test.(Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure)
Go to 3
3. (K136) MTV CONTROL CIRCUIT SHORTED TO GROUND
2. Measure the resistance between ground and the (K136) MTV Control circuit in the Manifold Tune Valve Assembly harness connector.
Is the resistance above 100 ohms?
Yes
Go to 4
Repair the (K136) MTV Control circuit for a short to ground.
4. (K136) MTV CONTROL CIRCUIT OPEN OR HIGH RESISTANCE
CAUTION: Do not probe the PCM harness connectors. Probing the PCM harness connectors will damage the PCM terminals, resulting in poor terminal to pin connection. Install Miller Special Tool #8815 to perform diagnosis.
1. Measure the resistance of the (K136) MTV Control circuit between the Manifold Tune Valve Assembly harness connector and the appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
Yes
Go to 5
Repair the (K136) MTV Control circuit for an open circuit or high resistance.
5. (Z816) GROUND CIRCUIT OPEN OR HIGH RESISTANCE
1. Using a 12 volt test light connected to 12 volts, check the (Z816) Ground circuit in the Manifold Tune Valve Assembly harness connector.
NOTE: The test light should be illuminated and bright. Compare the brightness to that of a direct connection to the battery.
Is the test light illuminated and bright?
Yes
Go to 6
Repair the (Z816) Ground circuit for an open circuit or high resistance.
6. MANIFOLD TUNE VALVE ASSEMBLY
1. Connect the Powertrain Control Module (PCM) connector.
2. Turn the ignition on.
4. Using a 12 volt test light connected to ground, check the (K136) MTV Control circuit in the Manifold Tune Valve Assembly harness connector.
NOTE: If the DTC is active, the actuation test may not be allowed by the PCM. If may be necessary to clear the DTCs before starting the actuation.
NOTE: The voltage supplied to the solenoid circuit during the actuation may be less than battery voltage. The test light should be illuminated, but may not be as bright as a direct connection to the battery.
Is the test light illuminated during the actuation?
Yes
Replace the Manifold Tune Valve Assembly in accordance with the Service Information.
Go to 7
7. POWERTRAIN CONTROL MODULE (PCM)
1. Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the Manifold Tune Valve Assembly and the Powertrain Control Module (PCM).
2. Look for any chafed, pierced, pinched, or partially broken wires.
3. Look for broken, bent, pushed out or corroded terminals.
4. Refer to any Technical Service Bulletins that may apply.
Were any problems found?
Yes
Repair as necessary.
Replace and program the Powertrain Control Module (PCM) in accordance with the Service Information.
