Results 1 to 8 of 8
    Brad SXT is offline LX Newbie
    Mar 2009
    nitrous on 4speed?
    I've read alot about running nitrous in a v6 with the 5 speed. What would be safest to run in a 4speed? I'm looking at a 100 shot right now. Anybody have any experience with this?
    torredtony is offline LX Padiwan
    Aug 2009
    bellmore/patchogue long island
    I'm gunna be running a 75 shot in my v6 5speed I'd say you might wana start with that just to be safe and you can always go up after. Ill let u know how mine goes I should be installing it in two weeks or so.
    Bryali's Avatar
    Bryali is offline Getting blown and hooked on meth...
    Apr 2006
    Upstate, NY
    I don't think the number of gears in the transmission would be as important as the engine itself. The transmission should be able to handle the extra power. The real question is how much can the motor handle. If I remember correctly, our engines have forged bottom ends. That means it can handle more abuse than another motor that's cast. The forged components are able to handle more heat and more pressure, which are results of nitrous use. As long as you can keep fuel and spark going, a 75 or 100 shot should be fine.
    I'm not running nitrous, but if I were, this is what I would do. I would recommend a window switch so that you can dial in the RPMs when your nitrous will fire. This will put the nitrous spray in the middle of your peak power band and give you the most bang (literally) for your buck. If you don't have a Diablo, I would get one. Use that to tune the car for a higher octane fuel. Nitrous really only supercools the intake charge, which compresses it. That allows more fuel and air to be compressed into the same amount of space (your combustion chamber). By using the higher grade gas will be squeezing the best stuff in the same space, which again means more bang for your buck. Again, I'm not using nitrous, but if I did, that's how I would set it up. Good luck!!
    2005 Magnum SXT: Fiberglass Hood, smoked LED tail lights, billet grille, Airaid CAI, Magnaflow Cat-Back, Polk Audio speakers, BT Catch Can, Debadged, Demolded, Predator 89 Tune, Ported & polished lower manifold, TB, and Jet Coated valve covers, front & rear R/T sway bars, longtube headers
    To Do Still: tint the front windows, wheels and rubber, and 1 MAJOR build going on right now...stay tuned...
    --new image coming soon--
    Mar 2009
    Quote Originally Posted by Bryali View Post
    good answer! I appreciate it
    Bryali's Avatar
    Apr 2006
    Upstate, NY
    Quote Originally Posted by Brad SXT View Post
    No Problem, I'm glad to help anyway I can. Also, if you go into the Power Adder's forum, you should find more people with more experience with Nitrous on our cars.
    wishing for hemi's Avatar
    wishing for hemi is offline power hungry
    Aug 2007
    back in the 7 cities. beach or bust
    my 3.5 has held up for a couple years now on spray 125 shot. the trans might be something to look at because i think the 4 speed is rated for a lower tq than the 5 speed. remember the trans still has moving parts and a lot of stress is transfered to all of your drive train not just the engine. i think you would be in the same boat as i was in the begining. give it a try but be willling to repair and replace if something goes wrong. n20 has gotten a lot safer but if you are not willing to shell out some serious cash to fix broken parts dont be the first to do it
    predator cmr tune, #1 v1 cams by inertia, 3000 stall by inertia, zex 125hp kit by hhp, stock srt cat back, 22" liquid metal turbines aar strips, racing stripes, front and rear mopower spoilers, steady growng collection of bt front badge door sills. honey comb grill.
    Mar 2009
    Anybody have a price tag on a 5 speed swap? If I do end up running into tranny problems I'd want to upgrade
    Aug 2007
    the trans itself used is from 800-1200 then a mount not sure if you have to get a new driveshaft. the bell housing might need to be chnged sepending on which nag1 you get. and a tcm also a wiring harness it would be a couple grand but well worth it for someone who has to mod their ccar
