Turbo system for the 3.5 V6 LX and Challenger models.
Okay, it’s been talked about for quite some time now, so it is time to get serious about it.
But first, I need some feedback from you V6 owners as to your interest and what you would want to see.
This would be an under chassis mount system. Why? Cost and complexity for anything different.
For cost considerations, the turbine outlet would be configured to connect into your existing single exhaust pipe in the tunnel. No exhaust system would be included beyond the turbine out pipe stub.
This will be a single turbo only system; a twin would only serve to drive up the price significantly.
The system will include a water/meth injection system as all my other designs.
It will not include an intercooler. If you must have an intercooler, have your shop modify the tubing to install one (air to water would be easier).
Most people already own a Diablo Predator, so one will not be included. As with our other systems, you have the choice of tuning with the iEMS3 or a CMR tuner of your choice. Neither option will be included in a basic kit.
What it will contain.
Single turbo
All 304H SS piping for hot and cold side.
40 or 50 MM wastegate
40 or 50 MM BOV
Silicone connectors
SS T-Bolt clamps
SS Torq-Tite exhaust clamps
Oil Scavenge pump
Oil Scavenge pump electrical control system and electrical bus combination
Electrical harness
Stage 1 water/meth injection system
Oil and vent lines
Air filter and inlet tubing
All mounting hardware, fittings, ty-raps, etc.
6 larger fuel injectors
Setup to run 7 psi, ESTIMATE + 100 RWHP and + 100-125 RWTQ.
Estimated MSRP $4,500.00 (if I can do it for less, I will)
The question is;
How many of you would be interested in a system as described at this price?
How many would be likely to purchase in the next 6 months?
Would you be more interested in a basic tuner system with NO water/meth injection and NO injectors priced at $3895.00 - $3995.00?
Your feedback will determine if this moves forward or not, so speak up.
