Results 1 to 5 of 5
    Lawndoc012's Avatar
    Lawndoc012 is offline LX Newbie
    Jul 2008
    Chambersburg, Pa
    Low Oil Pressure
    Anyone have any problems with the Low Oil Pressure light coming on. This only happens when I am stopping or turning. I checked the oil level and it was a little low. I topped it off and test drove but it still comes on. Any help/suggestions would be greatly appreciated. Thanks in advance.
    edit: forgot to mention no noises or anything like that.
    "LANDSCRAPER"
    Mics Mag's Avatar
    Mics Mag is offline LX Padiwan
    Mar 2009
    Windsor ON CAN
    Well, you've done what I would have suggested so lets assume there is an oil pressure problem. Has there been any recent work done on the engine? If not best to get looked at by a mechanic. It might be a sensor/wiring problem, but it may be the sensor indicating its low oil condition for a reason. Not something Id let go.
    07 STEEL BLUE MAGNUM SXT, JBA Headers, RT Exhaust w Magnaflow X, Predator tuner, BT Catch Can, Mopar CAI, Tinted, Cabin Filter, Curt 2" hitch recvr, Pro Series 48x32 Cargo Carrier with Bi-fold ramp, Munroe Air Shocks, Krown rust protection, debadged w SXT/6, Chally 18" alum rims, 225/60s.(winter) 235/55/17 staggered 215/60/17 (summer).
    Lawndoc012's Avatar
    Jul 2008
    Chambersburg, Pa
    ^^^ Thanks for the info. I have not driven the car since Friday, except to the shop last night. Having the pressure checked and going from there. Someone on CM said they have the same problem in their V8 and it turned out to be the Oil Sending Unit.
    "LANDSCRAPER"
    Mics Mag's Avatar
    Mar 2009
    Windsor ON CAN
    Lets hope thats all it is. Keep us posted.
    Lawndoc012's Avatar
    Jul 2008
    Chambersburg, Pa
    **Update** Low Oil Pressure
    Well I picked the car up last night from the shop and so far so good. I had them check the oil pressure at idle at that was normal (around 10-15). It appears that it was a combination of a Oil Sending Unit going bad (leaking from the center) and a bad oil filter. The cost was right around $100 to fix so I am very happy with that. Let's keep our fingers crossed that the issue does not return.
    "LANDSCRAPER"
