Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
Like Tree1Likes
Thread: Jba header questions.
  1. #16
    gunracer's Avatar
    gunracer is offline dsm n.o. member
    Oct 2009
    new orleans la
    Get u a magnaflow muffler and 1 of these
    2005-10 Dodge/Chrysler LX 2.7L & 3.5L 10db dual conversion kit w/SSR tips
    Thats the same set up I'm running and it sounds real good.
    southern hotrod dynoing my magnum - YouTube
    trufiber ram air hood, diablo sport tuner w/ 93 oct. gas on the 91 oct. tune, ported and polished lower intake manifold, ported and polished throttle body, magnaflow muffler, blastin bobs 10 db exhaust system with the 4" tips, big bully cia, big bully catch can, 160 degree stat, jet hot coated jba shorty headers, lowered and ridin on nitto 420's 255 45r20
    fastest time- 15.532@ 89.52
    "Speed never killed anyone. suddenly becoming stationary, now thats what kills you."
  2. #17
    BryGuy's Avatar
    BryGuy is online now GO SENS!!
    May 2011
    Markham, Ontario
    Dumb question but why shouldn't you use the gaskets that come with them?
    I'm about to have a set installed so curious....has anyone had negative experience with the JBA supplied gasket(s) failing and the failure wasn't due to the install procedure?
    Also, if you had to buy a second set of gaskets, why wouldn't you buy Fel-Pro gaskets instead of MOPAR?
    ...again just curious.....
    Quote Originally Posted by JCC300C View Post
    Get the mid pipes out of the way (2 clamps since you HAVE to disconect them from the manifolds anyway).
    DO NOT attempt to use the crap felt gaskets that come with the JBA headers, make sure to use the Mopar header gaskets.
    While you are getting your gaskets get a set of 6.1 header bolts or Stage8 locking header bolts <What I use>, but be prepared to reuse 1 old ones, the one with the dip stick tube attached.
    By far the easiest way to do this is to remove the head or the entire motor. Since that may not be an option your gonna F@#$ your knuckles up and you will not be able to get a torque wrench on most of the bolts. Torque is important here as these are Aluminum parts that heat up.
    DONT BUY JBA MID PIPES!!! THEY SUCK.
    300SRT rear spoiler / T Kutz Custom sill plates, ABS cover and firewall cover / emblems by Nate @ ReBadge / BT bling & catch can / braided line here & there / Red halos by the now defunct DLuxFX / Grant Revolution steering wheel w/ AMG paddle shifters & TRS300's wireless shift controller / Infinity V6 engine cover / 22" Boss 337's / Extreme Dimensions front spoiler / V6 custom tune by Overkill / JBA shorties / SOLO cat-back exhaust / SRT sways / Stoptech SS brake lines / Street Edge coilovers /LMI true CAI
  3. #18
    eGo's Avatar
    eGo
    eGo is offline LX Guru
    Mar 2008
    Leonardtown, MD
    Quote Originally Posted by wookinpahnub View Post
    The gaskets that come with them are just felt gaskets, there's really no integrity to them at all and they will blow out the first time you put your foot on the pedal. I don't see any reason why you can't buy Fel-Pro gaskets, I actually just reused my stock ones. No leaks and been working find for almost a year now.
    eGo
    Who Farted? BEANIE!!!
    !Welcome to the United States of the Offended!
    Mods : Inertia Performance Heads, Inertia v1.1 Cams, JBA Shorty Headers, Airhammer HO, Predator w/Custom Tune from Stu, RT Brakes, Eibach Pro Kit, RT Exhaust, 20" Vipers
  4. #19
    BryGuy's Avatar
    May 2011
    Markham, Ontario
    ^^ - good to know thx!
    Not sure what shape my originals are in but will use them if I can.
  5. #20
    gunracer's Avatar
    Oct 2009
    new orleans la
    I'm running felpro on mine right now and no leaks after a year. Just don't use the ones that come with. It's not worth doing the install a second time.
  6. #21
    09sxtsleeper is offline LX Newbie
    Sep 2011
    texas
    ok one more question I know its been a month since I started this... but Im about to pull my manifolds off.... and the sensors in the manifolds.... do they come out with a wrench? Or do I need a special tool? -_- please dont sayA special tool.
  7. #22
    Intense RT is offline LX Padiwan
    Feb 2012
    Central Ky
    Quote Originally Posted by 09sxtsleeper View Post
    IIRC from pics of 5.7 manifolds, should be 02 sensors. Go get an O2 sensor socket at the parts store. May be able to do a loaner tool deal. You pay for it, use it, return it.
  8. #23
    gunracer's Avatar
    Oct 2009
    new orleans la
    Just make sure when you do the install to never seize everything. Don't use the cheap stuff neither, u need the copper stuff. It's rated for 2000 degrees.
  9. #24
    Sep 2011
    texas
    Alright once I finish this I think I'm going to finally buy those dynomax vt mufflers and get rid of my system I have right now.
  10. #25
    Sep 2011
    texas
    So I ran into other problems and had to wait on the headers...... I finally just got a couple days off from work and I'm about to start the task of putting the headers on again. I have one more question, whats the torque spec on the header bolts goin into the heads?
  11. #26
    BryGuy's Avatar
    May 2011
    Markham, Ontario
    Below is an excerpt from the '06 LX service manual - left and right side should be the same
    "LEFT EXHAUST MANIFOLD
    1. Position the exhaust manifold (7) and gasket (1).
    Install the retaining bolts (2). Tighten 4 bolts starting
    at the center working outward to 23 N.m (200
    in. lbs.).
    When you attach the downpipes to the headers, make sure your cats clear the frame. You may have to loosen the exhaust bolts further down the line when you're tightening everything up to ensure clearance.
    I had mine installed yesterday and the installer said it was a bee-atch! He showed me cuts/scrapes on his arms so be prepared. LOL
    What a difference though!! - A little throatier at idle, much better sounding at mid to heavy acceleration and the power on demand factor brings a smile to my face every time. I think overall, you'll be happy with the results.
  12. #27
    BancoPopular's Avatar
    BancoPopular is offline LX Newbie
    Jul 2010
    This might be my next mod what's the turnaround on this at a shop and price range
    06 Dodge Charger 3.5L Special Edition {Midnight Blue Pearl Coat}
    Mods:
    Debadged,Mopar Cai,Blastin Bobs Dual Exhaust,OEM Projector Headlights,6K HID Kit,Smoked Side Markers,Tinted Tails,Tinted Windows,Diablo Predator 89 Canned Tune,71MM Mancini Ported Throttle Body,Interior Blue LED Lighting,Dimpled Drilled Slotted Rotors,18Inch RT Wheels.
  13. #28
    gunracer's Avatar
    Oct 2009
    new orleans la
    the shops around me kept quoting me 400 for the install and you would have leave your car over night to allow the engine to fully cool down. i saved the 400 bucks and installed them my self in 5 hours. plus what the shop doesn't tell you is that if they break a bolt getting the old headers off there gonna charge you to remove the head and get the rest of it out. highway robbery if you ask me.
  14. #29
    VenomNST is offline LX Padiwan
    May 2009
    Ooltewah, TN
    I am glad this thread was started. My project plans included JBA Shorty headers, Magnaflow Cats, and a custom exhaust w/ cutouts. Do you all recommend new O2 sensors with a full exhaust upgrade?
  15. #30
    gunracer's Avatar
    Oct 2009
    new orleans la
    Not unless u need them. There expensive. And becareful with high flow cats, they make our v6 sound more like a 4 cyl Honda and really gain nothing. That is out the mouth of a magnaflow rep to me when I thought about it.
