My maggie was smoking a little from under the hood. I can't see where the smoke is coming from, however, i'm guessing it may be coming from the egr valve but i'm not 100% sure. Has anyone else had an issue with a smoking egr or a smoking engine???
Is it at first start cold start or after running awhile?
Is it all the time?
at idle or under acceleration or after acceleration?
what type of smoke gray/white?
Any type of smell?
Blinker Mod, Auto Headlight Mod,91 Pred Tune
Fog light Mod, Shaved and De badged,Silencer Delete,Hood Struts,Strut cover,Modified Exhaust Flo-king muffler Dual out with Resonators Deleted.
It usually starts when the engineis cold. After it warms up a little, I can see the smoke. It is very light and smell almost like something oil based is burning. I cannot pin point the smoke but it seems to be coming from the driver side of the engine.
If you have any clue let me know.
Thanks
If the R. valve cover gasket is leaking, the oil will seep down onto the EGR valve.
www.ramtruckforums.com
is the oil cap on good/what about the vent tube is it covered
