Results 1 to 4 of 4
    surg is offline LX Newbie
    Apr 2009
    Check engine light
    Hi guys just thought i would ask a quick question.
    Does anyone know if the Check engine light stays on then flashes a few sec then stays lit again when the switch is put in the run position?
    I can't remember if it flashed before. The light doesn't stay on with the engine on.
    I may be a bit paranoid seeing as i noticed it after i upgraded the battery's ground to a bigger cable.
    Thanks for the help guys.
    SKULLBOY's Avatar
    SKULLBOY is offline Veritas Aequitas
    In A Bunker......
    Quote Originally Posted by surg View Post
    If you turn the ignition switch pass accessory to the "On" position without starting the car, the Check Engine light will come on and stay on.............If the light isn't on when the car is running then it is all good.....
    If the Engine light comes on when you are driving you usually can still drive.........However if the engine light comes on while driving and starts to flash and beep, then STOP and pull over Immediately.......that means something is seriously wrong.......
    HEMI Registry #1575
    CarDomain Page: http://www.cardomain.com/ride/3926528/2007-dodge-charger-srt8-sedan-4d/page-1
    RunningBull's Avatar
    RunningBull is offline LX Padiwan
    Jan 2007
    LongIsland N.Y
    you rested the adaptives it will go away
    in a few hundred miles or sooner.It does this
    if you pull fuse 11 also.
    Blinker Mod, Auto Headlight Mod,91 Pred Tune
    Fog light Mod, Shaved and De badged,Silencer Delete,Hood Struts,Strut cover,Modified Exhaust Flo-king muffler Dual out with Resonators Deleted.
    MikeEast's Avatar
    Ducktown, Georgia
    Put the key in, turn it to 'On' and watch the CEL, within 20-30 seconds it might start blinking.
    If it only blinks once, that's normal - if it blinks 10 times then you are not in 'emissions ready' status and will fail an emissions test. You'll need to drive it for several 'cycles' - normal everyday driving.
    How many cycles and how long it takes are things I don't know. I drove the 4 lane for 4 exits and took the little roads back and it went ready by the time I got back to the emissions place.
    Your mileage shouldn't vary...
    Mike
    edit: it does this after an F11 pull like RunningBull mentioned, a battery disconnect like you found and also after writing any tune with a tuner.
