Results 1 to 15 of 18
    rwalshphoto's Avatar
    rwalshphoto is offline Matte White Wagon
    Phoenix, AZ
    42RLE (4-Speed) Symptom & Solution
    So sometime about 6 months ago I started chasing a ghost of a problem with my car. At this time I had been going through a lot of changes with the tune trying to resolve some issues and thats when the problem started popping up. Oddly enough my friend Nate (BritishNate) was in almost the identical circumstances - similar mods, similar tune, same time frame, same symptoms. This ended up being a complete coincidence as far as I can tell at this point.
    The Symptom:
    At random speeds when the car would downshift it was like the transmission wouldnt engage - almost like pushing the clutch in on a manual transmission. It would happen at completely random times and at different speeds and in different gears. This would occur maybe once every other week or so. Sometimes it seemed to do it more if the car was under more load when I had more people in the car or stuff in the back.
    Because of lack of funds I just dealt with it for several months not wanting to just blindly throw parts at it without a sure solution. Well, I came into a turn pretty hot the other day expecting to drift/power through it and the car dropped into the lower gear like it was suppose to, was in power and car was sideways and boom it does its shift thingy and all of a sudden no power to carry through the turn. Luckily nothing bad came of it but enough to make me take action to fix it - lol.
    The Solution:
    My first guess was fluid level and or the correlation with temperature changes - no dice. I spent quite sometime searching for threads on here and other forums and finally Nate found a hint in a old thread on another forum that pointed to the speed sensor. So I bought some from Ted and Jeff at AllUSA and swapped them out on saturday. There are two speed sensors - an "upper" and a "lower". Not knowing which was bad and not having a starscan to do the tests to find out I bought both.
    These are the part numbers and prices:
    4799061AB Speed Sensor $30.23
    52854001AA Speed Sensor $25.71
    The speed sensors look like little plastic cylinder with rubber o-rings on them to seal into the trans and they have a flange around the outside with a hole where it bolts to the side of the trans. Its took me maybe 10min to change both sensors. Only tool needed is an 8mm wrench - ratcheting wrench preferred. The back sensor has a small magnetic nose on the tip of it - mine had quite a bit of metal shavings.
    So far the results have been far better than expected. Besides the fact that it hasnt done its weird disengage thing, the shifts seem to be more predictable and more accurate. It seems to have taken care of a couple other symptoms that I just wrote off. The car used to sporatically bog off the line, pretty much at least once every trip. So when I would go WOT on launch it would sit there and bog and when it got into the middle RPM range the power would come on like a light switch... almost like i was launching from 2nd gear. Hasnt done this once since I swapped the sensors. Overall the car is just more driveable. I really have no idea how much these speed sensors affect the actual TCM or whatever adaptives or anything else it may do with the inputs but its seems to have fixed it.
    Starting over with a new Magnum RT (SRT8 Conversion)... 6.1L with SRT Max Cam, Corsa catback with chambered center pipes, Sinister Extreme dual ram intake system, SRT Suspension, silver Brembos, graphite powder coated Charger SRT wheels, frost white intake manifold (ported) and valve covers, matte black engine bay, carbon fiber engine accents, 300C SRT8 Front end, Matte White vinyl wrap, Black Ops 300-Challenger style carbon fiber hood. Project "SnoMachine" all work performed by Arizona Hemi Specialists - Plum Floored Creations, Mopar Automotive Photography
    todd0218's Avatar
    todd0218 is online now 3gcustomz sales rep
    Jun 2007
    Michigan
    interesting... seems there isnt a ton of knowledge on the 4 speed but this is interesting. Its a bummer you dont have a video or something to really visualize the car in its ill symptoms per say.
    MAGFX is offline Nevermind my mind!
    Dec 2005
    Arizona
    Good job, Ryan, on figuring out the problem.
    I smile because i have no idea whats going on.
    My friends call me JONN (usually).
    Phoenix, AZ
    I took a video a while back on my camera phone and you could hear the it downshift and the tach jump but the speedometer wouldnt move. When it would do this it would sit there and bounce on the "neutral" rev limiter until I would let off.
    BritishNate's Avatar
    BritishNate is offline How Dare you...She's a Nice Lady!!!
    Phoenix, Arizona
    good write up ryan i will let you know when i have money to buy those....
    AZ Modern Mopar Muscle
    Said goodbye to the Maggie and Hello to the Sorento
    JarZ's Avatar
    JarZ is online now Ole sad på en knold og sang
    Union County, NJ
    Yep the exact same thing happened to me a week after I bought the LHS (same transmission basically), but the car went into limp mode and mechanic said "you need a new transmission". So I went to dodgeintrepid.net with the code thrown by the car and voila - busted speed sensor.
    $70 later, INCLUDING PARTS (I also did both sensors) it was good as new and has been running like clockwork since.
    Ah the power of the internet
    Glad you got it fixed.
    2005 Bright Silver Dodge Magnum R/T - Inertia 5.7 heads/Spartan cam/JBA headers/AFE II/BB Fat Pipes/402 Motoring spoiler/tinted tails
    2006 Brilliant Black Dodge Magnum SRT-8
    5.7L & 6.1L Hemi Registry # 856
    JarZ@Inertiamotorsports.com
    Please call us at 512-964-7724/862-215-4668 or send me an email for any questions about our products.
    Find us on Facebook Or @inertia392 on Twitter
    Phoenix, AZ
    Cool. Mine never threw a single code though
    Phil056 is offline Madison & Morgan's Dad
    Smithtown, Long Island
    Did you ever try and pull Fuse 11 to see if that remedied the issue? - I Guess since you haven't had any issues it was those parts, thanks for the #'s, saved them in my part list document.
    '05 Magnum SXT - Inferno Red
    Protection, Performance, Leather Pkgs.
    Boston Acoustics Pkg w/ Sirius
    Phoenix, AZ
    Quote Originally Posted by Phil056 View Post
    I cant count how many times Ive pulled fuse 11 or reset the TCM by pulling the battery, etc since the issue started...mainly for other reasons but yeah...no help.
    SKULLBOY's Avatar
    SKULLBOY is offline Veritas Aequitas
    In A Bunker......
    Quote Originally Posted by rwalshphoto View Post
    This is the exact problem I have had since my S/C install......Mine is a constant "bog" off the line............haven't had the downshift problem though........
    I might have to try replacing those sensors and see if the gets rid of the bog off the line..........
    HEMI Registry #1575
    CarDomain Page: http://www.cardomain.com/ride/3926528/2007-dodge-charger-srt8-sedan-4d/page-1
    Zoban's Avatar
    Zoban is online now lil Red Wagon
    Feb 2008
    Oshawa Ontario
    Sort of a thread jack but related ..
    What options do we have for high Stall TC's in our 4spds ?
    2006 Lil Red Wagon SXT
    Modlist : AFE Stage II, JBA Headers, Corsa Catback, 20" Vipers, Cross Drilled Rotors, Diablo Bob@SVS Tuned, Pioneer DEH-5000UB, 12" Enclosers, Halos, Low/Fog HIDs, Cuda Grille, TruFiber Chally Hood.
    at the Track
    My Garage
    Mentoria Computer Consulting
    Phoenix, AZ
    Quote Originally Posted by Zoban View Post
    I dunno, I talked to Stu about it a while back and I think ProTorque can make one but I havent heard of anyone taking the plunge. I'd personally be worried something would give in the trans with hard launches but pay to play I guess.
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    Hmm.. that sucks .. will have to keep eye out and maybe if $$ work out right be the first to plunge in on this one..
    at the Track
    My Garage
    Bryali's Avatar
    Bryali is offline Getting blown and hooked on meth...
    Apr 2006
    Upstate, NY
    Unfortunately, the swap for a 5spd is pretty involved and expensive. That's what I've gotten from looking around on here and other forums. Who knows, maybe someone will come up with a plug-and-play 5spd or a "built" 4spd.
    2005 Magnum SXT: Fiberglass Hood, smoked LED tail lights, billet grille, Airaid CAI, Magnaflow Cat-Back, Polk Audio speakers, BT Catch Can, Debadged, Demolded, Predator 89 Tune, Ported & polished lower manifold, TB, and Jet Coated valve covers, front & rear R/T sway bars, longtube headers
    To Do Still: tint the front windows, wheels and rubber, and 1 MAJOR build going on right now...stay tuned...
    --new image coming soon--
    SKULLBOY's Avatar
    In A Bunker......
    Quote Originally Posted by Bryali View Post
    Coming from a friend who works in a transmission shop, these transmissions are not cheap to rebuild.....you can almost by a brand new one for the cost of a rebuild..........
    I asked Stu about the Interia 3500 stall TC for my 4 spd.......he told me not to bother........to blow up the 4 spd and replace it with the 5 spd and then get the highstall TC..........
    I have a inquiry into a fellow forum member who works at the Brampton assembly plant to see exactly what is involved in converting to a 5 spd..........I know a wiring harness and TCM will be required along with the transmission itself........since the swap from 4 to 5 spd was a mid year change in 2006, it can't really be that much of a difference or difficult to swap, as you would think that they would want to keep things simple to keep running smoothly on the assembly line without a lot of indepth changes/interuptions..................
    HEMI Registry #1575
