Results 1 to 12 of 12
    7186dodge's Avatar
    7186dodge is offline LX Newbie
    Jul 2009
    edmonton alberta
    3.5 v-6 timing belt
    What is the time line on 3.5 timing belt replacement i have 30,000 km but the car is almost 4 years old does it need to be done ??????? or maybe not
    NC-SXT's Avatar
    NC Coast
    150km acording to fnkychkn
    WWW.DodgeMagnumGrille.com
    fnkychkn's Avatar
    greasy cardboard box
    maintenance schedule says 175,000 km. i wouldn't push it that far so i'll be replacing mine at 150,000 km. i also suggest you replace the water pump at the same time.
    7186dodge's Avatar
    Jul 2009
    edmonton alberta
    what about a time line i wont own the car(maybe) at 150000 but i remember they would say to replace old hoses and v-belts every 4 years.
    fnkychkn's Avatar
    i would change it at 6 years..
    7186dodge's Avatar
    Jul 2009
    edmonton alberta
    MagNite is offline LX Guru
    Rochester,N.Y.
    Anyone know how much $$$ (USD) it cost to have the Belt & water pump replaced on the 3.5L? How much labor time wise is involved? My Magnum has almost 86k on it so it won't be long before I hit the 100k mark. Before the end of the year definately. I know the manual says 105k, but I always do the maintenance a little sooner than what the manual says. Preventive medicine and all that....
    fnkychkn's Avatar
    Quote Originally Posted by MagNite View Post
    can't give you US prices but you can approximate from these canadian prices or call your dealer to check prices.
    timing belt P/N 4792353 $220.00 cad.
    belt tensioner P/N 4892109AA $184.00 cad.
    water pump P/N 4792968AD $113.00 cad.
    water pump O-ring seal P/N 4792982AA $14.75 cad.
    expect to pay anywhere from 3-6 hours labour, depending on the shop.
    lowryder99 is offline LX Padiwan
    Apr 2009
    Edmonton, AB
    Damn those are expensive (dealer prices) I got a jobber belt for $140, tensioner was $60 and the pump was $50
    Bryali's Avatar
    Bryali is offline Getting blown and hooked on meth...
    Apr 2006
    Upstate, NY
    WOW....I'm just thankfull I have a decent set of hand tools and a huge supply of DIY!! Most jobs can be accomplished either by doing it yourself or payment in the form of frosty beverages and pizza/hot wings!!
    2005 Magnum SXT: Fiberglass Hood, smoked LED tail lights, billet grille, Airaid CAI, Magnaflow Cat-Back, Polk Audio speakers, BT Catch Can, Debadged, Demolded, Predator 89 Tune, Ported & polished lower manifold, TB, and Jet Coated valve covers, front & rear R/T sway bars, longtube headers
    To Do Still: tint the front windows, wheels and rubber, and 1 MAJOR build going on right now...stay tuned...
    --new image coming soon--
    rwalshphoto's Avatar
    rwalshphoto is offline Matte White Wagon
    Phoenix, AZ
    Quote Originally Posted by Bryali View Post
    Honestly the only real challenging part about the whole job is getting the timing right while working the belt on and everything. The rest of the job is as simple as unbolting stuff.
    Starting over with a new Magnum RT (SRT8 Conversion)... 6.1L with SRT Max Cam, Corsa catback with chambered center pipes, Sinister Extreme dual ram intake system, SRT Suspension, silver Brembos, graphite powder coated Charger SRT wheels, frost white intake manifold (ported) and valve covers, matte black engine bay, carbon fiber engine accents, 300C SRT8 Front end, Matte White vinyl wrap, Black Ops 300-Challenger style carbon fiber hood. Project "SnoMachine" all work performed by Arizona Hemi Specialists - Plum Floored Creations, Mopar Automotive Photography
    Rochester,N.Y.
    Yeah I'd do it myself if I had the time and a place (ie. a garage)to do it in. Unfortunately I live in an apartment complex that doesn't want you working on cars in the parking lot and it's winter here, so I'm screwed both ways. Geez I remember when I used to change the timing belt on my Dodge Aries K-car station wagon with the 2.2L . Just had to unbolt one of the engine mounts on the right side of the engine, pull off the plastic cover, unbolt the camshaft pulley, and pull the belt off. To install, just do the reverse making sure the timing marks on the camshaft pulley were aligned and it was done. I don't think there was even a tensioner on those. Those 2.2L's had to be one of the simplest engines to work on!
