Alright, it's a long story, so I'll try to make it brief. Stock 3.5, no upgrades, 87 octane.
The car runs rough 99% of the time. Not rough as in a lopey cam, more like it's running on 5 (or 4) cylinders. Had been getting a 0304 (cylinder 4 misfire) code at this point. Ran Seafoam through it a few different times a few weeks apart.....seemed to help the idle for a few days, but then back to normal.
Took it into my Chrysler dealer, said it was a bad coil pack on cyl 4. Replaced it.
Few days later, the problem shows back up. Took it in and the dealer said the same coil pack crapped out, replaced it again...for free.
Few days later and the same problem, but it's starting to get worse. Took it to an independent shop. They looked it over, said they thought it was either a bad EGR, EGR needs flashing, or PCM needs flashing. They can't do it since Chrylser doesn't give them the updates to do this work until 4-5 years after the vehicle production (supposedly).
So I take it BACK to my dealership. First they tell me it needs new plugs (57,000 miles right now). They wanted to charge $180 for the plugs and install. I tell them I will do it, just put the intake back on.
I stop by later that evening to pick it up, but the mechanic and the guy at the service counter were both gone for the day. The notes on my invoice said to run some engine/fuel injector cleaner through to see if it helps. If not, it probably needs a fuel injector on the cylinder. Well, I've ran the engine cleaner through twice already, not doing it again. So the vehicle limps home. Somewhere in here, the 0300 (multiple cylinder misfire)code pops up. I throw new plugs in it a few days later.
It's been around a week and MAYBE 100 miles since I changed the plugs, and the engine runs just the same, if not a little worse, than it did before. I pulled the plugs out again today, and they are all pretty black and sooty. Still have the 0300 code. First 3 pictures are drivers' side bank, forward most, middle, and rear most (I think cyl 2,4,6). 3 pictures in next post will be passender side bank, forward most, middle, and rear most.
Anyways, I'm about at my wits end with this engine. Could a bad EGR valve cause all this chaos? What about a bad injector? Am I wasting my time/money installing just ONE injector?
Sorry for the long rant, but any help that anyone can provide would be greatly appreciated.
Thanks in advance,
Jared
