Results 1 to 15 of 15
    James L's Avatar
    James L is offline LX Padiwan
    Sep 2007
    Cambridge, Ontario
    07 SXT w/5speed auto and the new Stage1 Jet Chip review
    Didn't know if anyone would be interested in this, but i recently installed the Stage 1 Jet Chip for the 3.5 and thought i'd share my thoughts, in case anyone was considering the same mod.
    Currently have:
    K&N Panel filter
    10w30 synthetic
    the chip took about 5-10minutes to install (mostly due to trying to fit it back in carefully)
    after the battery was reconnected, started the car, problem free.
    have driven aggressively city driving to finish off the tank of gas... and see what's it's like.
    WOW, i won't say that it's smoking the tires, but the shifting is MUCH more responsive. No lag, it just goes.
    the autostick seems to shift a little quicker as well.
    passing at highway speeds, revs quicker.
    the drive is definitely more fun now.
    I'm actually testing the mileage now by babying it and seeing what happens (without resetting the ECU again) i want to see how long it takes to learn what i'm doing
    non-aggressive driving, i've hit 575km a tank
    aggressive driving, i've hit 480km a tank
    aggressive with chip, i've hit 490km before the low fuel light.
    '07 Magnum SXT - Diablosport Predator, K&N, Blastin Bob's Dual Exhaust, Flowmaster, R1 rotors and pads, shaved & debadged, Charger lip, splash guards, RT rear-bumper, Tinted Tails, roof-rack
    Kevlar's Avatar
    Kevlar is offline Silver Hammer
    Sep 2007
    Lindale, Texas
    Sounds good i need to get one. Thanks for the Review
    06 Charger 3.5L HO MOD's :
    1. 20% tint
    2. Flomaster Exhaust
    3. K&N CAI
    4. 20'' Cruiser Alloy Rims w/275/45/R20
    5. Datona Style Spoiler
    6. D'Badged, D'Molded
    7. ESP Mod
    8. Retro "Bumblebee" Stripe, Rocker Panel Stripe
    http://www.easttexasmodernmopar.com
    06 Charger 3.5L HO MOD's :REDISCOVER THE WEB FIREFOX 2.0 DOWNLOAD IT NOW http://www.getfirefox.com
    silk08's Avatar
    silk08 is offline LX Newbie
    Miami,FL
    cool glad you like the jet chip i was woundering if anyone knows if you can have a b&g flash and still run the jet chip is this possible ??
    RixMag's Avatar
    RixMag is offline '06 SXT AWD
    Jun 2006
    N.Kingstown, RI
    Hmm. Temptation beackons thee.
    "For in the baby lies the future of the world. Mother must hold the baby close so that the baby knows it is his world. Father must take him to the highest hill so that he can see what his world is like." -Mayan Proverb
    DCX rides:
    "Magnum R.I"
    2006 Magnum SXT AWD, 3.5L w/sunroof. AIRAID CAI & Bumper Shield.
    Useful data: .7Kw=1 HP, 1 Nm=0.738 ft-lb TQ
    BSG:
    ToddStone's Avatar
    ToddStone is offline Bug Killer Extreme!
    Spokane, WA
    I noticed a difference in my truck with the just a Airaid CAI and exhaust. I was actually able to spin my tires just a little bit (AWD) in wet pavement. I'll probably buy another one.
    Mods: Big Bully/Spectre Cold Air Intake; R/T Exhaust;JDM Headlights; SRT Sways; Tinted Windows;Boston Accoustic Speakers and 10" sub, Crunch 500 watt power amp; KW V1 Suspension/Coilovers; Predator Tune; Fog Lights; 71mm TB and lower intake; HoneyComb grille; JBA Headers.
    Jimsmag06's Avatar
    Jimsmag06 is offline Is now an 07 SXT!
    Patterson,Ca
    Hey James, Thats some good info!
    Have you noticed a slight hesitation in your transmission in the mornings....I have an 07 that I just got 6 weeks ago, and, Im hoping this is normal.....I drive a tow truck most of the time, so she only has about 850 miles on the clock. I`m going to have them check the fluid level when I take it to have the GPS theft tracking system installed.
    Jim
    07 MagSXT
    JBA Headers, R/T exhaust
    MY357's Avatar
    MY357 is offline All Show
    Racine,WI
    I have been thinking about getting the JetChip Stage 2 for my 3.5...
    ChargLex's Avatar
    ChargLex is offline Powered by the 3.5L V6 and proud of it
    21 miles from the LX factory
    Quote Originally Posted by Jimsmag06 View Post
    My NAG1 transmission is also quite sluggish off the mark especially once the temperature dips.
    However, it seems mine is a victim of the leaky o-rings so my fluid might be down a bit. Wish I could check but on this German trans this has become a big dealership procedure now
    Regards,
    ChargLex (Lex at Chargerforums)
    2006 Charger SXT 3.5 NAG1 5spd autostick · DiabloSport Predator 93 Tune · Ceramic Coated JBA Shortie Headers · AirAid CAI · Custom Magnaflow Dual Exhaust · Modified DC Sports strut bar · MyGig RER NAV with Lockpick Adapter (PAC Line-In Adapter FOR SALE) · Pinnacle ceramic 35% tint
    SKULLBOY's Avatar
    SKULLBOY is offline Veritas Aequitas
    In A Bunker......
    Quote Originally Posted by James L View Post
    The Jet chips actually do nothing for the transmission/shift points.
    The chip strictly adjusts/modifies air/fuel ratios and timing curves curves............
    A few members have contacted Jet and asked them and were told the above.........
    If you haven't pulled the fuse or disconnected the battery previously, you might just be seeing the result of clearing the PCM of past driving history..........
    From the Jet Website:
    Point by point air/fuel ratio, ignition advance and various other tuning points provide performance gains of up to 25 horsepower. Improves throttle response, acceleration and low end torque.
    Stage 1-For stock or mildly modified vehicles. Fuel and timing curves are modified for optimal performance and mileage using less expensive, lower octane fuels. Programming is designed to burn fuel at peak efficiency, which results in improved performance and mileage. Daily drivers can use lower cost regular fuel for potential mileage gains, but for optimal performance gains use of mid-grade or better is recommended.
    Stage 2-Designed for the performance enthusiast, the Stage 2 features more aggressive programming to make the most horsepower and torque available. Fuel and timing curves are extensively modified for peak performance and drivability. Requires use of 91 octane fuel, 180 degree thermostat and free flow exhaust. Also works well with aftermarket intake systems, mass air sensors, TBI spacers, etc.
    I run the Jet Stage II chip and noticed quite a big difference in performance over stock.
    SKBY.
    HEMI Registry #1575
    CarDomain Page: http://www.cardomain.com/ride/3926528/2007-dodge-charger-srt8-sedan-4d/page-1
    magnum4sissies's Avatar
    magnum4sissies is offline LX Newbie
    Nov 2007
    SKBY, do you run 91oct fuel while receiving this large difference in perform?
    07 Magnum SXT
    James L's Avatar
    Sep 2007
    Cambridge, Ontario
    sorry haven't checked this thread in a while...
    i came across the same thing from Jet... i was just stating what it felt like.
    putting 89 octane instead of 87, has also produced interesting results...
    again, car feels more responsive, and even though i'm driving more aggressively city/hwy driving, gas consumption hasn't gone up any.
    i'm averaging about 500km per tank of 60L
    if i baby it, i get more.
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    If you get the B&G flash you'll want to throw the jet chip in the trash cus it's no longer needed :D
    lamtutu is offline LX Newbie
    Dec 2007
    Quote Originally Posted by SKULLBOY View Post
    [/font][/size][/font]I run the Jet Stage II chip and noticed quite a big difference in performance over stock.
    SKBY.
    Hi.
    Can you show me where Could I buy Jet State II chip for my Chrysler 300 V6 3.5 L
    Thanks
    Briant
    James L's Avatar
    Sep 2007
    Cambridge, Ontario
    I got mine from the guys at SocalMotorsports.com
    ChargLex's Avatar
    There will likely be a pile of 'em on the used market as soon as the V6 tuner starts shipping (ETA seems likely to be a few weeks from now).
    Regards,
