Results 1 to 14 of 14
    Charger4Life's Avatar
    Charger4Life is online now I'd rather be racing.................
    Greenville, South Carolina
    06 5.7 R/T TCM in a 3.5L Nag 1?
    Can someone tell me if this will work properly. My buddy is having trouble getting good shifts out of his 3.5L and I was gonna let him try an extra TCM I have for my R/T.
    Thanks
    Frank's SPARROW cam, Indy Maxx heads, LMI Fender Pull Intake, Edge High Stall Converter, Full SRT exhaust, 399 rwhp, 407 ft.*lbs.
    5.7 N/A 11 second club Best times to date:
    1/8 mile E.T. 7.42 @ 93.53 mph.
    1/4 mile E.T. 11.696 @ 114.24 mph.
    1.60 60 ft. best
    InferAl's Avatar
    InferAl is online now "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Quote Originally Posted by Charger4Life View Post
    Thanks
    Does he have a 4 or 5 speed is it a Nag1
    Video
    Quote Originally Posted by InferAl View Post
    He has a 5 speed Nag 1. cause he said it shows 5 in autostick now.
    1.60 60 ft. best
    Fargo59's Avatar
    only issue would be gear ratio. otherwise i can see it working. he'd need higher shift points than stock RT's though.
    3.5's use the same TCM as the 5.7 and 6.1, it's all programming differences.
    InferAl's Avatar
    Nov 2006
    NE Ohio
    He could try it, it may be the same TCM being it is a Nag1........what rpm does it shift at now
    It may be simply cause it is a 3.5 that it doesn't shift as good
    Video
    InferAl's Avatar
    Nov 2006
    NE Ohio
    Quote Originally Posted by fargo59 View Post
    What gear would they put in a 3.5 with a Nag1, I know the 4 speed 3.5 is about a 3.56 or 3.6X can't remember
    Video
    I'll have to find out what his shift point is. He updated his CROM and now it isn't shifting as good. He says it feels like the convertor unlock for a split sec. then goes to next gear.
    1.60 60 ft. best
    InferAl's Avatar
    Nov 2006
    NE Ohio
    I think ther new croms get worse as they go, I keep r12
    Video
    65standard's Avatar
    65standard is offline Programmer/Fabricator
    Dec 2008
    Chicagoland
    Quote Originally Posted by inferal View Post
    what gear would they put in a 3.5 with a nag1, i know the 4 speed 3.5 is about a 3.56 or 3.6x can't remember
    2.87
    Tony
    MidnightSXT's Avatar
    MidnightSXT is offline LX Guru
    P.G. B.C. Canada
    Quote Originally Posted by 65standard View Post
    2.87
    Yes,unfortunately this is true. Mine is a 2.87
    ToddStone's Avatar
    ToddStone is offline Bug Killer Extreme!
    Spokane, WA
    Same, I think that's pretty much all the way around. I think if you get the Predator it can reprogram it for ya.
    Mods: Big Bully/Spectre Cold Air Intake; R/T Exhaust;JDM Headlights; SRT Sways; Tinted Windows;Boston Accoustic Speakers and 10" sub, Crunch 500 watt power amp; KW V1 Suspension/Coilovers; Predator Tune; Fog Lights; 71mm TB and lower intake; HoneyComb grille; JBA Headers.
    392Stu's Avatar
    392Stu is offline Supporting Vendor
    Nov 2006
    After doing that 4.0 L stroker on the 3.5 All I could think was the 3.73 getrag differential swap would be too cool. That combined with a TCM that had 7K plus RPM upshifts. The little 3.5 likes to run upstairs when modded.
    Six Offenderl and builder of the finest Fiat Hemi stroker engines.
    todd0218's Avatar
    todd0218 is offline 3gcustomz sales rep
    Jun 2007
    Michigan
    Quote Originally Posted by 392Stu View Post
    man i cant wait to see you guys do more modding on the 3.5l, i have been watching for more advancements and breakthroughs daily. LOL. i know the 3.5l isnt a powerhouse, maybe never will be but you guys are one of few that took initiative to fulfill the needs of us 3.5l owners.
    Deuces is offline Predator Installed!!!
    Roselle, IL
    The Predator is the way to go... Tuned out, my 3.5 would bark the tires into second occasionally. Always crisp shifts.
    '06 Stone White SE - Predator 93 Octane Tune Installed! ~~~ SOLD ~~~
