Results 1 to 7 of 7
    BToohey44's Avatar
    BToohey44 is offline Average Joe
    Nov 2005
    New Tripoli, PA
    Spark plugs and wires
    Has anyone changed their spark plugs and/or wires on their 2.7s. I know they are supposed to be good until 100k put I would like to change them both out.
    I plan on doing some preventative maintenance this spring with trans fluid, rear diff fluid, brakes (pads and rotors)...you get the idea.
    Cheers
    2E
    2008 Subaru Impreza 2.5i - Stock
    SOLD
    2005 Dodge Magnum SE - Magnaflow Catback Exhaust Magnesium Pearl
    cm2005300's Avatar
    cm2005300 is offline The New "Milli Vanilli"
    Bc
    no but bump i would like to know
    MOD LIST : NOT ENOUGH!!
    Reeg's Avatar
    Reeg is offline www.ChecktheBlog.net
    FrozenNorth MN
    As would I... Bump!
    bookeem's Avatar
    bookeem is offline All Black Everything!!!
    north jersey
    same here, to the top...
    Thank You Haz
    strat04 is offline LX Newbie
    2.7's have no plug wires..only coil pack
    cm2005300's Avatar
    Bc
    Bump
    BToohey44's Avatar
    Nov 2005
    New Tripoli, PA
    Quote Originally Posted by strat04 View Post
    Yeah, thats what I get for trying to post on two different boards at the same time. After I had posted it, I caught that I put plug wires.
    Thanks.
    So far I've found four candidates.
    Bosch Iridium Fusion
    Bosch Platinum+4
    Bosch Platinum+2
    Autolite Xtreme
    Will probably go with the autolites or the Bosch Iridiums, we'll see.
    Cheers
    2E
    SOLD
