Results 1 to 9 of 9
    pgcharger's Avatar
    pgcharger is offline Midnight Run 2
    Jan 2008
    El Paso, TX
    question on demolding and debadging
    i know so cars with the small molding like the charger has it has pins along with the dub sided tape is that the same with the chargers? or can i just pull it off and clean up where it used to be? thanks in advance
    blackmagnum06's Avatar
    blackmagnum06 is offline me la mames en reversa cabron!!!
    southern ca
    no pins or clips on the molding. it is glued with adhesive. just get some heat lamps fishing line and do it slowly.
    bigdog425's Avatar
    bigdog425 is offline LX Guru
    everett wa
    ya it is such a good look. i did it on my 300 made a world of diffrence.
    Demon's Avatar
    Demon is online now I don't have ADH... SQUIRREL!
    Jan 2008
    OKC ~ Between lost and lost
    Planning on doing this myself... supposed to snow tomorrow so doubt I will be out there with my heat gun any time soon...
    Too many people buy things they don't need, with money they don't have, trying to impress people they don't even like...
    Where am I going again and why am I in this handbasket?
    BUTWEET's Avatar
    BUTWEET is offline GOOD MEAT TAKES A LONG TIME!
    Bothell, WA
    Definitely not something to do in cold weather.
    MY MEAT WILL MELT IN YOUR MOUTH....NOT IN YOUR HANDS! ENJOY THE Q.
    pigpen's Avatar
    pigpen is online now Kluck Fabrication
    Minnesota
    Cold weather will suck big time.
    It is best to use a hair dryer to heat them up a little bit. Then use goo be gone to get rid of the crude.
    Demon's Avatar
    Jan 2008
    I've got an OLD heat gun, works really well for moldings... I bet it could even do the job while it was snowing... I just wouldn't be LOL
    Bruce Bruce is offline LX Newbie
    Nov 2007
    Sugarland Texas
    If you put in chrysler demolding on you tube, it shows you a simple visual on how to take it off
    sublime195's Avatar
    sublime195 is offline LX Padiwan
    Jul 2007
    rochester mn
    I just de-moulded my sublime and it was only about 25 degrees. Was easy to do. Just be paitent and a hairdrier will work good. The trick is to get tthe moulding started. With mine the tape came off with the moulding.
