I have the 5.7 Hemi, and i'm currently running R18, 93 performance cai tune, with raised tranny shift points, increased shift firmness, wot fuel 3.5% richen across the board, egr removed, rev increased 200 rpms over stock, speed limiter increased 190mph(yeah rite), and i set all my fans 5 degrees below the tune setting which is 199 degrees. I have been tweaking and modifying the settings the past for weeks to see what will give me the most power. I'm real interested to see what settings you guys have changed and what changes are giving you the most power?
All performance work done by mdmperformance.com
You aren't going to gain much from tweaking the tune unless you have some motor work done to your car or at least long tubes. What are your mods?
Originally Posted by JusticePete
My Pedders ExperienceOriginally Posted by JusticePete
