Results 1 to 15 of 18
    hemicanucksfan's Avatar
    hemicanucksfan is offline so many projects, so little money
    toronto area (ajax)
    saving modified canned tune?
    i had to take the car into the dealer today for some electrical gremlins so i loaded the stock tune back into the car. then when i reloaded the 91 octane tune later i had to go back and change my preferences again. is there a way to save the 91 tune the way i have it set up right now, or am i stuck with having to set it up again every time (ie. shift points, tire size, rev limiter, etc.). thanks for any help.
    2010 LX&Beyond Nat'ls Best In Show Magnum Daily Driver
    2011 LX&Beyond Nat'ls Best In Show Magnum Weekend Driver
    2-toned, trufiber srt hood, 22"x9.5" gray Foose Nitrous, colour-matched headlights w/halos, 6000K HIDs (lows/fogs), tinted marker lights, colour-matched fog bezels, tinted tails, Airhammer, Eibach Pro-kit, Predator, Edelbrock headers/cat-back, jba hi-flow cats, 82*C thermostat (180*F), remote start, MDS indicator, Mopar hitch. So far.
    metgo's Avatar
    metgo is offline Life is too short to be driving slow
    St. Louis
    I'm not really sure there is a way. I haven't really played with canned tunes much because I've had a CMR tune since I've had my predator. If there is a way, I'd like to know because when I return my car to stock I lose all my changes that I made to my CMR tune.
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
    toronto area (ajax)
    so i'm guessing this can't be done?
    nhdave's Avatar
    nhdave is offline This space for rent.
    New Hampshire
    After you make your modifications to the canned tune and write it to the PCM you can go in under "custom tune" and "export last tune written"(I think that's what it named). Then download it to your computer/laptop and you can rename it from there.
    06 Inferno Red Magnum SRT8
    Pretty stuff: Blinker mod, Silverstars, Auto Headlight, ERF Backups, 22Elite console w/Jina's stitching
    Go-fast stuff:
    Arrington 426 w/607 cam and FRI Heads by BFNY Performance, Tuned by HemiTuner, Kooks, Protorque 2800, Airhammer, 180 t-stat, Cool-It, B&B Catback
    11.973@112.45 N/A
    11.42@117 - 1.579 60'
    juiced
    metgo's Avatar
    St. Louis
    Quote Originally Posted by nhdave View Post
    I think if you export the last written tune, if it was a canned tune, it will export the canned tune without the changes you made to it. I honestly don't think there is a way to do it.
    nhdave's Avatar
    New Hampshire
    Can't hurt nothing by trying it.
    CanadaDude's Avatar
    CanadaDude is offline ‹(•¿•)›
    Sep 2007
    Oakville, Ontario 2007 Dodge Charger 3.5L v6 Police Package
    Quote Originally Posted by hemicanucksfan View Post
    Quote Originally Posted by metgo View Post
    Obviously, his last tune written is a modified 91 tune, so by exporting his current tune, it will work.
    I have what is now known as a 93 "beta" tune, a custom tune from Diablo based on the 93 tune that has the idle fixed, and the decel rate about the same as stock. After modifying it further with changes to REV limiter and a couple of other things. I then exported the last written tune, renamed it, re-up'd to the Predator, made some description changes, and uploaded to the car. It retained all the extra changes I made. So it worked for me.
    As for shift firmness, and other functions that are separated from the tune, I don't think they are saved with the tune and may have to be re-done each time.
    If Diablo could create a "profile" function into the Predator, so you can upload your profile to vehicle, which would include your tune, shift firmness, TCM adaptation, tire size and whatever else all in one shot, that would be REALLY cool!
    CanadaDude
    diablotoona's Avatar
    diablotoona is offline NOOB....
    Jun 2007
    Delray Beach, FL
    Canadadude is right.
    The only thing that does not get saved with a export of last tune written is the auick adjusts, that you will have to redo, everything else gets saved.
    One note however, when you do the last tune written export and reload it into the predator it will ask you to reset the parameters, you should do so, if not it will apply those changes on top of the changes you have already made, which will throw off your tune considerable.
    Johan <at> diablosport.com
    DiabloSport R&D
    Only two things are infinite, the universe and human stupidity, I am not sure about the former.
    CanadaDude's Avatar
    Sep 2007
    Quote Originally Posted by diablotoona View Post
    Ok, I think I need a tiny clarification. When I sent my modified 93 tune to you folks, and got back the supermodified "beta" 93 tune, I uploaded that to my Predator and then to the car. I don't recall if it asked to reset the parameters or not. If it did, I would have probably said NO, thinking it was going to set the new tune from you back to something else.
    Should I put the stock tune back in, delete all the custom tunes, and re-load the 'beta' tune back into the Predator, and finally into my car again?
    I'm confused. (Easy to do)
    toronto area (ajax)
    thanks for the help guys. cheers.
    metgo's Avatar
    St. Louis
    If the quick adjust doesn't get saved, then what would be the point in saving a canned tune?
    mnunes's Avatar
    mnunes is offline That guy
    Jun 2005
    Fountain Valley, CA
    You can still adjust things like WOT spark and fuel, fan settings, EGR (I think that's in the tune, not QA).
    How do I.... EVERYTHING!
    SoCalLX - Where Southern California Car Culture Meets Modern Mopar Muscle
    LouZ's Avatar
    LouZ is offline LX Guru
    Dec 2004
    NY in the mountains
    Is this the reason the "exporte last tune written" is smaller in size than the origional custom tune?
    Lou -05 Magnum RT AWD ---> FRI'd 392
    Mike@Diablosport's Avatar
    Mike@Diablosport is offline Supporting Vendor
    Jun 2007
    Ft. Lauderdale
    Quote Originally Posted by LouZ View Post
    Is this the reason the "exporte last tune written" is smaller in size than the original custom tune?
    Yes, it is only exporting the changes in the file.
    LouZ's Avatar
    Dec 2004
    NY in the mountains
    Quote Originally Posted by Mike@Diablosport View Post
    So if I install a different custom tune the exported one is no good.?
    How can I get a entire export of the installed tune?
