I have the U7136, V6 Predator and I have looked and looked and can not find how to log RPM while logging KR so I know what rpm my engine is pulling timing. Also I don't see anywhere to disable the ST KNK Sensors.
Was this an oversite or am I just blind?
We no longer give you the ability to dsable Knock sensors, this is only available in custom tuning, and not recommended...
Log RPM and LT_KNK and ST_KNK, along with actual timing cyl. 1.
Thanks
Mike
Ahh, its under a weird group name, EPDSS if i recall correctly.
Johan <at> diablosport.com
DiabloSport R&D
Only two things are infinite, the universe and human stupidity, I am not sure about the former.
Yep I finally found itSince we can't disable KNK sensors would it be feasable to put a reistor in the line to reduce their sensitivity by 30-50%
We reduce the knock sensitivity quite a bit in the tunes, i really do not see any need to reduce it more. They are there for a reason and in stock format they are way to sensitive hence we de-sensitize them a bit.
We can always make you a custom tune with less sensitivity.
