Results 1 to 5 of 5
Thread: DataViewer Help
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    DataViewer Help
    I have a Mac based laptop and was trying to record some logs for a tune and the program will not recognize the tuner once the USB is plugged in. I do have Windows XP on my Mac so I thought that would work, but I guess it doesnt. Is there anything I can do or something I am doing wrong? Any help is greatly appreciated.
    '05 Magnum RT: 392 Twin TC70 Turbo Build
    Orange Crush 375's Avatar
    Orange Crush 375 is offline Prius owners: Thanks for the extra gas!
    Feb 2008
    Land of 10,000 Lakes
    Mine works fine running XP under Parallels. I needed to use the menu bar at the top of the screen to give XP control of the USB port. Also, I needed to install the USB>Serial driver on XP and reboot.
    2008 Daytona #375 "Orange Crush"
    Call Sign KC9LEM 146.940 Tone 103.5
    Yeah, she's bone stock, I swear it...
    MagnumRT05's Avatar
    Jan 2007
    Westlake, Ohio
    What do you mean USB>Serial Driver? The program works fine, but it just wont recognize when I plug the USB in. Will try your suggestion later. I greatly appreciate it.
    Feb 2008
    The USB to Serial port driver allows your computer to use the USB port to connect to the Predator handheld's serial port in serial mode. Without it, your computer will probably not know what protocol (it will try to use either USB or serial neither of which is correct) to initiate synchronous communication.
    MagnumRT05's Avatar
    Jan 2007
    Westlake, Ohio
    I got it to work kinda. I had to install the latest build via the update screen as I had build 3014. Now it says I need to install the software from the mini-cd I was sent. My MacBook doesnt allow mini-cds so how did you get yours to work???
