Looking at getting a cam installed soon with Longtubes, exhaust and air hammer, already have the predator....now my question is I also have a torque converter that I will be putting on in a month or so after...should I wait to do the cmr tune after the torque converter or will it be ok doing the tune before the tq is installed??? Thanks for the help
Mods: 6.1 motor with PPP Ported Heads and 224/228 598/578 113LSA, stock tq converter, stock SRT headers with gutted cats, JBA 3in exhaust, LMI hammer design intake. The only 6.1 motor running a 2.82 rear.....Soon to be 3.06 gears.....Installs done by Afterhours Mopar Performance
Tuning before the converter is fine and you will not need a retune after its installed.
9.18 @ 150 mph
Thanks FlyByU thats kinda what I was hoping for.
Prolly see better numbers with the stock converter too...
Johan <at> diablosport.com
DiabloSport R&D
Only two things are infinite, the universe and human stupidity, I am not sure about the former.
Ya, we get some slipage thats for sure, lol.
Hemi Registry 0436 6.1 block - CTP Dual intake - Modern Muscle ported intake manifold - Indy Heads - PWR cam - FTI converter - TTI Longtube(catless) - 3.06 gears - 17 X 8.5 Borbet TS w/ 275/40 Hoosiers - Diablo tuned!! Billet Tech Goodies EVERYWHERE. ALL Parts supplied by LXF vendors: Afterhours Mopar Performance, SpeedRated, PWR, Modern Muscle, Picklefork...and LXForum members. Installed by: Afterhours Mopar Performance
BigHemi06-
SSOoooooo....Add you to the tooning list?? for the 17th/18th?
Yeah, i see that all the time and customers get disappointed he he.
You'll get a better tune with the tight converter.The dyno will have more control of the motor.Manual transmissions are even better.On a rolling dyno you can't simulate a launch.The lower the tuning rpm the better for flashing the loose converter with sticky tires.
I think that made sence?
Bob
LXBuilder@Yahoo.com
Ok
In order to get good AFR numbers you need to stabilize the engine at each rpm step so the Accelerator pump function doesn't skew the readings.The better your motor is tuned in this area the better it will respond when loaded hard against a sticky tire.Some cars will blow away a street tire then fall flat on they're face with a good tire.
Hope that makes more sence
What's going on on Sunday
World's first tuned V6 LX!!
-Jimmy aka Jimbo
