I've been using the Predator for over a year now with no apparent problems, but today was different. I had the Predator installed on my 08 SRT8 Charger, but I wanted to use it on my 05 R/T Magnum just for today. I put the Charger back to stock and that went fine, I hooked the Predator up to the Magnum and changed most of the Quick Settings before trying to put the performance tune in. After reading the factory tune, I attempted to install the 93 Performance tune, after a few second the Predator gave me a "Close" screen and while I was sitting there in WTF mode the Predator started smoking. Luckily nothing in my Magnum seems screwed up, but I haven't taken a drive in it yet.
Buyer Beware!
holy crap man. Hopefully the mag is OK. Hard to tell until you try and drive it if the tune got partially written and messed up as a result. Definitely time to call Diablo on this one.
Current mods: Hi-Flows, 180. Volant, PS Cooler, Trans Cooler, SS Brake Lines, Ti Backing Plates.
Pedders Track II Extreme, Wavetrac, Moroso oil pan/catch can, 6.1 MTCM, Mopar trailer hitch.
Happened to me and others. Car should be fine. It's a problem with 05 Mag R/Ts for some reason - can't remember the specifics.
5.7L & 6.1L Hemi Registry # 856
JarZ@Inertiamotorsports.com
Please call us at 512-964-7724/862-215-4668 or send me an email for any questions about our products.
Find us on Facebook Or @inertia392 on Twitter and www.inertiamotorsports.com!
Past Mopars:
2005 Dodge Magnum R/T
2006 Dodge Magnum SRT-8
2000 Chrysler LHS
1999 Dodge Intrepid SE
If you updated the Crom on the Predator between that time and now, it could be the cause. I tried running version 12 or whatever it was and the Predator went up in smoke. Went back to version 08 and it's flawless.
This issue only shows up randomly in early build 05 models.
If you want to fix it for use in the 05, please fill out an rma request and send it in.
It should still work fine in the 08.
This Predator definitely worked in my Magnum before I purchased my Charger and I have a very late build 05 (March 05).
What's this going to cost me to make right?
If you need to borrow a predator let me know, I have mine sitting in a box at the moment...Given that this was a known issue I would think it's a warranty item?
426 STROKER 11.5CR built by Ding's. INERTIA STROKER CAM, Paramount Trans/TransBrake/TC/FLEX/DS/8.8 Differential with 4.10 gears, rwhp 758/ 731 rwtq
PB N/A 10.948 @ 124 w/-200DA
Nitrous PB 10.19 @ 136 MPH
Is Diablo making this right with you Becker?
2007 Dodge Charger SRT-8
Current mods: SRT Max cam, Inertia Performance heads, aFe Stage 2 CAI, SLP underdrive pulley, MM ported throttle body, ported intake manifold, Paramount 4000 TC, Magnaflow midpipes with high flow cats, BT catch can, 180 tstat, Getrag rear, Zeitronix ZT-2, Hotchkis anti-sway bars, Razor's Edge shock tower brace. Installed by Troy @ Ding's Auto. Tuned by Johan.
No prob, let me know if you need anything.
Glad to hear you're back up and running Becker!!!
