Now that I'm finished with the front fender moulds, I'm kicking around once again the idea of making a rear widebody as seen in the 2009 danko charger renders, but I was thinking now that people would want it wider than the stock rear quarters unlike my original plan of just making the top part fatter. If I was to do this, how much wider should I make the rear? seems to me like it should be between 1" to 2" wider to hold some fatter meats on the back.
i like it now, but if you did atleast 1 1/2 to 2 inches you can tuck 12 inch wides easy under there
or u can do like 3 feet like topo does!!! jaja
1 1/2 seems to be a compromise size, but would that make it a hard to work with number - are even numbers the easiest to work with? Is there a size that would make everyone happy? the 12" guys and the 10" guys? 2" is quite a bit and would require lots of rim. What width does ToPo do really?
I think anything less than 2" (overall average) is a waste, not enough of a visual impact to justify the time or money.
i have seen 3 charger by topo and they are impressive, his widdening measurments are perfect..... that 1 1/2 on top and 3 on wheel is nasty....
i wish i could go wide body like that real soon, lets get this started MO!!!!!
MO, u got my PM?
2011 Charger FTW!
the hell with the rear make the fascia already will ya?!
RIP NHDave
Bingo!!! Make the front as erik says i got my credit card ready to gooo!!!
High Comp 392.
OK, now that I know topo did 3", I'm more comfortable with 2". The top measurment is irrelelavant since I'm going for a different look, more of a vertical squarish quarter.
