Page 1 of 6 123 ... LastLast
Results 1 to 15 of 77
Like Tree20Likes
Thread: Danko Charger WIDE BODY Finally FINISHED!!!!!!!!!!
    mopower's Avatar
    mopower is offline Designer jeans for your LX!
    Feb 2006
    Miami,FL
    After 2 1/2 LOOOOOONG years, this product is officially FINISHED! The price is $1,695 + $295 for the tubs upgrade and we are taking orders. Any questions?
    [IMG]
    http://i227.photobucket.com/albums/d...oductions/Rear Wide Body/WidebodyHardware2copy.jpg[/IMG]
    Sdotzsrt8man's Avatar
    Sdotzsrt8man is offline LX Padiwan
    Jun 2010
    Buffalo, WV
    What do you expect the install time would be at a good body shop?
    Jun 2010
    Buffalo, WV
    also just looked how do you open the rear doors
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    oooooooh mercy.. my wife is gonna hate you...
    And the dead shall walk
    maverickmann's Avatar
    maverickmann is offline Here to enjoy the ride!
    Aug 2008
    Reynoldsburg
    That...is...sick!
    Quote Originally Posted by richierevs View Post
    Each and every one of our cars is an expression of ourselves. It is a travesty when someone wrongfully abuses our trust without sympathy, remorse, and restitution. It's downright sinful.
    mopower's Avatar
    Feb 2006
    Miami,FL
    OK so lets get started on the install. First we have to get the fuel situation taken care of before we install the fiberglass panels. My car had very little gas in it so I got no spillage but I'm not sure what would happen if it was full, you may want to avoid filling the car up before surgery. The first step is to remove the metal pipe from the fuel tank to the gas cap. It is easily accesible just beneath the plastic inner fender liner. Just undo the hose clamps and retaining screws and it pops right off. The vent line also has to come off and it has a connection that un-snaps. In the first pic you see where to cut the main pipe 2" north of the bracket. To keep little bits of metal from getting in your fuel line, I made a little thingy with some wire and a metal nut, wrapped it with a paper towel and shoved it into the line below where I was gonna cut, then cut it with an air powered hack saw (wire and all) and then pulled the wire out to clean the debri from the inside of the pipe. The other side is cut about 1-1/2" south of the weld as seen in the pictures.
    Now besides the hole I had to cut into the quarter panel with a 4" hole saw to make space for the Lid assembly, I also had to cut a relief hole in the metal quarter panel where the round fuel hole is. this is because our fuel cap is relocated upwards and we need more space to clear the vent line. 2 slices with an air powered hack saw does it, then just push the metal in out of the way.
    mopower's Avatar
    Feb 2006
    Miami,FL
    Quote Originally Posted by Sdotzsrt8man View Post
    Next time you enter your car, just reach in from the front and see how easy it is to open the back door. You can also buy the remote solenoids like they use with shaved door handels. If someone wanted the handels on there, I'm sure I could custom install them into place...
    We custom modify each Fuel Door assembly at the factory by grinding the locking tabs and sanding the gelcoat completely off the inside beveled edge to make the fuel cap snap in properly. When priming and painting the car, be carefull NOT to build up the beveled seat area, as then, the cap may not snap back into place when assembling the car!
    In order to install the fuel hoses, you need to temporarily install the fuel cap assembly. Once the assembely is seated in the hole, flip it over and take a flat end screw driver to push the 4 locking tabs outward.
    Now lets now get back to the Fuel hoses install. Once you're done with that step, insert your factory Charger fuel pipe, rubber gasket and all into the Fuel door assembly. It slides in and fits like a glove just like OEM!! Now you can hang the wide body panel in place with a few screws. Make sure to put the Cap in place and close the door so it is in the exact right place when installing the hoses.
    The hoses should already be cut in the correct length so it's pretty easy to assemble. In order for the hoses not to interfere with the plastic inner wheel liners, you need to stick the big hose under the metal shock tower lip and use a couple of straps to keep it in place. The factory brackets and vent hose connections are used.
    This is what it should look like when it's all done!! Now we are Old School all the way! pretty cool huh?
    Now if you want to remove it before painting the car, this is how it's done: First unhook the hoses/clamps, then you need a pretty long flat screw driver to reach up inside from underneath. Depress each of the four tabs while twisting on the housing and the assembly should pop right out. It's a little hard to see and reach as you can see from the last pic, but it's definitely doable, just get someone to hold a light for you while laying on the brakes/roter assembley (ouch!). Remember not to get too much build up of paint in the seat when painting the car! That's all for now, stay tuned for more updates!
    Jun 2010
    Buffalo, WV
    I actually like the way it "shaves" the rear handle
    EXTREME's Avatar
    EXTREME is offline shopHEMI.com
    Oct 2005
    Virginia
    I've followed this for a long time. It's good to see if finally hit production.
    How does the rear bumper get modified. Does it fit with no mods?!
    Fidostudio's Avatar
    Fidostudio is offline CAMM CREW
    Jul 2010
    Chicago
    Damn...love that!!! I've had the pic as my wallpaper for months now. Gonna have to pull the trigger on this soon!
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    What would be a reasonable charge for a body shop to install and finish these out to be ready for paint?
    spenosk8er's Avatar
    spenosk8er is offline Sickest Charger on my street
    Los Angeles
    Congrats on finishing it! Looks awesome. If anyone gets a body shop quote please let us know too!
    lowriderman3's Avatar
    lowriderman3 is offline Rut Ro!
    Low Down Dirty South!
    That is sweet! Now on to the 2nd Gen wide body kit!
    NYC
    sooo.... has anyone purchased/installed this yet? Mo, do you have it fully installed on your car yet? I'd love to see some finished (or at least completely assembled) pics.
    FOR SALE: 2006 Dodge Charger RT - 6.1 motor, Novi 1200 blower, Treadstone A/A FMIC, 392 fuel pump + KB BAP, Siemens 70# injectors, 190* tstat, 3.06 rear, Diablo Trinity, Tuned by Josh @ HHP, catless mids, Full Brembo setup, SRT steering & electronics, KWV2 suspension, Hotchkis sways, BWoody endlinks, SPC/Eibach UCAs, SRT fascia & spoiler, Trufiber SRT hood, MSRT wheels, 6000k HID lows/fogs, LED headlamps, SRT seats, MyGIG, 1ST COMPLETE '06 to '08 INTERIOR CONVERSION, ... & a bunch of other sh!t I cant remember!
    gbneufeld's Avatar
    gbneufeld is offline ALX FTW
    Sep 2009
    Calgary
    Quote Originally Posted by rev.hammer View Post
    what would be a reasonable charge for a body shop to install and finish these out to be ready for paint?
    x2.
    Not just another pretty fascia
