Do you guys all have SRT's?
I personally only use the Sunoco 94 in my Firebird and it has 11.6:1 compression. My RT Hemi is only 9.6:1 and an SRT is 10:3:1.
I am sure most of you realize that higher octane fuel does not have more energy in it. It only has a higher resistance to knock, because it burns slower and colder. If you have a higher resistance to knock, you can run more compression and spark advance. Those 2 things have horse power in them. More compression only comes from changing to smaller chamber heads and or pistons. Spark advance can be changed with a tuner.
As a matter of interest, most of our higher octane fuels we can buy have more ethanol than regular and therefore has less potential energy in it. Ethanol has a lower calorific value than plain gasoline. So if you use premium in your car and it was designed and tuned for regular or mid grade, you likely get poorer mileage and possible build ups in the combustion chamber since the fuel is burning slower and colder than it was designed for.
My RT has the Flashpaq tune in it which advances the spark and therefore needs the 91, instead of the 89, but I would never put the 94 in it unless I was taking it to the track on a very very hot day as a precaution. BTW it would likely make a little extra hp with the 91, as long as the PCM did not see any knock and retard the spark.
My personal use of fuel:
-Firebird Sunoco 94
-Magnum Esso 91
Hopefully some of you find that interesting.
http://en.wikipedia.org/wiki/Octane_rating
