Results 1 to 5 of 5
    bal's Avatar
    bal
    bal is offline bal9162
    Sep 2007
    surrey bc
    Exclamation starting the magnum and blck smoke
    who can help when i start my magnum up in the morning or after a few hours its been parked. it throws out grey black smoke then comes a slight smell of oil then its fine its the 3.5i ho with 42,500k
    Wellsy's Avatar
    Wellsy is offline The Rocket...425hp HEMI powered.
    Feb 2008
    Langley B.C. Canada 2007 Charger SRT
    Quote Originally Posted by bal View Post
    I have a 6.1L and noticed a ways back after letting her sit for a day, when I started it up, there was a puff of blue. It scared the **** out of me. There is no need to be alarmed, if this is the fix though. I asked the same question and the answer may be that you need an oil catch can. Start inquiring on the Search LXForums, there is tons of info on this issue...good luck.
    .....The Rocket - 6.1 Hemi Registry #956....
    narts's Avatar
    narts is offline Chopped 'n' Screwed
    Jun 2006
    Surrey, BC, Canada
    ^^^I've read the same thing here on the forums, oil catch can could be the answer.
    2005 Magnum RT
    J Field's Avatar
    J Field is offline She's Now Bottle Fed!!!
    Sep 2007
    Coquitlam B.C.
    it's not uncomon to have a small puff of smoke after a engine sits for awhile (especailly if the motor has over 40k) oil will bleed down, the only time this is bad is if it won't stop burning oil.
    Personal best 11.82@114mph
    Jet 180 Thermostat, Nitrous Outlet Perimeter Plate, AirRaid CAI W/Scoop, CMR tuned, PT 2800 stall Converter, ZEX Complete Nitrous Kit, Stage 2 268H-13 Comp Cam, Iridium 2 Heat Range Colder Plug, Custom Built Dual Flowmaster Exhaust, Hedman long tube headers & Cat's Deleted, Line lock, AEM Wideband, Autometer Nitrous & Fuel Gauges, Glow Shift Triple Guage Pillar
    Kuldip's Avatar
    Kuldip is offline BCLX member 001
    burnaby, BC
    time for a new car.
    We must question the story logic of having an all-knowing all-powerful God, who creates faulty Humans, and then blames them for his own mistakes. – Gene Roddenberry
