HI guys . I need some help please . I need to tap into a PINK wire from my fuse box for my ignition . ANy ideas would help . Thanks2 many . Dont want to screw up
3 piece chrome grill * k&n airraid * jet performance chip * 2.5" into flowmaster strip 40s with 3 inch out * hotchkis swaybars, * boss 335s 20" on toyo 245 45 20s * various painted interior pieces *various billet dress-up pieces * 8000 hids * clear bulb front turn signals * hood struts * R1 concepts rotors and brake pads * Universal air suspension * fully adjustable koni front struts and rear shocks * custom head rests and custom tonneau cover by Bobbi at RJ's Leather Magic
Do you need one under the hood or inside the car? You can get a 12v ignition at the ignition switch, pink/white wire. Under the hood, looks like at the fuse box, fuse 27 pink/orange should be 12v ignition, i'd check it with a test light or multimeter to be sure. What do you need to hook up to the ignition?
I made a mistake, thats not the box under the hood, its the one in the back by the battery. This manual is confusing.
