Results 1 to 12 of 12
    MagnumMark's Avatar
    MagnumMark is offline MagnumMark
    Nov 2005
    Calgary
    Creak / Rattle Noise ...driving me crazy
    Looking for some help so I don't have to bring this to the dealer just for a creak/ rattle...
    It's in the right hand area of the dashboard. It sounds like it's coming from the glove box, but there's nothing in the glove box.
    Has anyone had this problem??
    Help!!
    CReaky Crazy in Calgary
    2005 Magnesium Magnum RT
    Calgary, AB
    UnderTaker's Avatar
    UnderTaker is offline Bring out your dead!
    Oct 2004
    Norwalk, Connecticut.
    man i hate noises... cant say i have had that prob - yet... all my sound comes from the rear....
    05 Blk Magnum RT RWD,Window Tint, Mopar CAI, B&G PCM Flash, Magnaflow Cats, Borla 125, "HEARSE" vanity plate, AR/311 20" wheels W/Goodyear F1 245/45/20, 4X R1 D&S Rotors, LED tails, AAC Halo's suck - replaced with 402 motoring lights (sweet), Custom LED turns, Wired V1 W/Remote Disp, Kenwood Excelon 715dvd w/ NAV, iPod, 2x Diamond Hex 6.5, Eclipse Titanium DVC 12" w/custom enclosure, JL 1000/1, 2x JL 300/2, 2X Optima Batt. w/ Isolator, Rear Shaved, R Sylvania Turns
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    I believe that there is a TSB for an interference of a screw in the dash near the base of the windshield.
    Da moighty CHKN will most likely give total scope on this!
    And the dead shall walk
    marmaduke's Avatar
    marmaduke is offline LX Padiwan
    Feb 2006
    Toronto
    I have a rattle coming from the drivers side sunroof area... Going to have the dealership look at it on the next oil change.... As for the glove box, loaded and no problem.
    2006 300CSRT8 - 2006 MSRT8 - 2006 GCSRT8
    MagnumMark's Avatar
    Nov 2005
    Calgary
    Quote Originally Posted by Rev.Hammer View Post
    Thanks for the help. At least if there's a TSB, that means they might know what they're looking for.
    Mark
    Calgary, AB
    Ozzie's Avatar
    Ozzie is offline LX Goo'Roo
    SoCal
    Check the retaining clips on the piece that covers the right side speakers. If one of them is not seated properly it will cause a rattle. This solved the problem for a few people.
    The TSB is for a popping/crack noise from the base of the windscreen.
    MagnumMark's Avatar
    Nov 2005
    Calgary
    Sorry for the ignorance, but where are the retaining clips??
    Thanks
    Mark
    Calgary, AB
    DeepSIX's Avatar
    DeepSIX is offline Mopar or NoCar
    Feb 2006
    SW Ontario
    I have been having that problem. It was only when the wife was in the car!!
    But it has been happening all the time now. I also seem to have the noise from the speaker area. I will pop the cover off this weekend to see what I see.
    I will call the dealer on the TSB about the popping sound.
    Quote Originally Posted by Ozzie View Post
    Mopar or NO Car
    2005 Magnum RT
    1998 Neon Sport
    1988 Dakota 4X4
    1968 Plymouth Barracuda
    1965 Vespa SS180
    1983 31' Airstream Excella
    MagnumMark's Avatar
    Nov 2005
    Calgary
    Mine is definitely at the base of the windshield
    Thanks for all the help
    Mark
    Calgary, AB
    boggart's Avatar
    Pittsburg, KS
    the front piece of the dash on the right side over the dash speaker is where my rattle is coming from. I can see the dash bouncing. I did it myself I'm sure though when I installed the dash speakers. I need to take it all back apart to make sure it's clipped together correctly.
    MagnumMark's Avatar
    Nov 2005
    Calgary
    How do you get that speaker cover off on the dash?
    Calgary, AB
    SERBS_HEMI_C is offline LX Padiwan
    Jan 2006
    Oswego, IL
    Quote Originally Posted by marmaduke View Post
    this might help the dealer so they dont fu*k with you about it..
    http://www.wkjeeps.com/misc/LX/TSB/TSB_2300206.pdf
