sounds to me like the ALT failing or the belt is slipping..
you should be at 13.8 - 14.1 (depending on what electrical items are running) while the engine is at 2,000 RPM
13.5- 13.8 at idle
and 12.5 - 12.7 with engine off...
I run a solid 13.8 at all times under full load (A/C on high, stereo (2500 watts) at full, HIDs (headlights/tail-lights on) under normal load (radio at decent volume, A/C on Auto, Headlight on or off) I run 14.1 volts..
For the record I have upgraded wiring (00 gauge from ALT to battery, and 00 gauge on the Battery Ground) A Kinetic 2250 Battery and a 10 Farad Capacitor for the sound system.
definitely sounds like something is not right...
how old is your battery? What is the Voltage without the battery in the car?
have you checked the battery ground point? are any cables frayed or damaged?
