hey guys I recently bought a set of srt8 wheels thanks to geraldk's post. but being a impulse buyer I never thought to check the offset, any input?lol i'm dumb i know but a steal of a deal so worse case I'll sell them
im pretty sure they do
I believe the awd rims have a different offset but all the rwd rims have the same offset. Shouldn't be a problem but try one on the front.
Assuming your 3.5 is a RWD you'll need 3mm spacers for the fronts. The rears will fit just fine.
Get these:
http://www.custombilletstore.com/product_p/4000.htm
They are the best ones available, and from a kicka$$ vendor.
12.645@108.18
,,, demoulded...say no to chrome
, jina's upholstery console cover,, hid drivin lites,,
wish list -- more upholstery work.,,, rims, exhaust.. air brushing.
thanks guys, now i know. I actually have a set of spacers in my trunk that i bought trying to get another set of wheels to fit that i had from my old mustang. I told you I would need them someday bryank47, LOL
SRT8 Wheels will fit non-SRT8 LXs without spacers, but there will be rubbing issues.......You will need 3mm spacers for the fronts in order to get a proper fit.......the rears are good to go......
It is not the Caliper clearance that is the issue......the SRT8 wheels clear the SRT8 Brembo Calipers, and they are a lot bigger then the stock 3.5 or R/T calipers............. It is tire rub that is the issue..........when the wheels are turned to full lock you will get tire rub.......My buddy found this out when he installed SRT8 Magnum wheels on his 3.5L Charger before he knew about the spacers............
And as bandaid mentioned, AWD wheels are a completely different off-set.........
HEMI Registry #1575
CarDomain Page: http://www.cardomain.com/ride/3926528/2007-dodge-charger-srt8-sedan-4d/page-1
