Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Thnd3r
Thread: CAD in Calgary?
    Dr Teeth's Avatar
    Dr Teeth is offline LX Guru
    Nov 2006
    Calgary, Alberta, Canada
    CAD in Calgary?
    Any ALXers in the Calgary area have access to a CAD program and printer? I oredered a sink for a bathroom reno but it won't be available for 3 more weeks, and without the template the granite company can't cut the countertop, which in turn is holding up my tile setter. However the template is available on the Kohler website, but I need access to a CAD program and printer to download and print it. Can anyone help me????
    2006 300 SRT8. Black. Razors Edge Shock Tower Brace, Diablo Predator with custom tune, Torque Thrust M's, Nito Invos, BT catch can, gutted cats, Pioneer AVIC Z140BH.
    goldSE's Avatar
    goldSE is offline SNOOGANS!
    Aug 2010
    Taber, Alberta
    Let me talk to a friend of mine. He just graduated from SAIT where he took mechanical desgin and engineering and used CAD programs on a daily basis. I'll see if he's still got connections.
    Thnd3r's Avatar
    Thnd3r is offline Let the Mods Begin!
    Jan 2012
    High River, AB, Canada
    What size do you need it printed? Maybe you could post a link to the template?
    crazy_luck's Avatar
    crazy_luck is offline I know where Hoffa is...
    Belle Plaine, MN
    In theory, the shop cutting the granite should be able to use the template available from Kohler on their own. They should be able to put it directly into their CAM software to program the CNC machines to cut it out. The only thing you should really need to do is inform them which one they need to use - with no need for you to print it out.
    (I worked 2 years in a cabinet shop and I've been trying to get into Cambria, which is a company that makes simulated granite counter tops)
    Dr Teeth's Avatar
    Nov 2006
    Unfortunately, this shop doesn't use CAD CAM. As for the link to the template, this is the Kohler site for the sink: KOHLER Canada: K-2824: Serif® undercounter lavatory: Sinks: Bathroom From there click on "For Installers and Designers". The file is listed under "Cutout Template". It's a DXF file.
    Thnd3r's Avatar
    Jan 2012
    I just emailed the dxf file to myself. I'll take it to the high school I work at on Monday to see if I can print it for you. If I can't get it printed, you could always try Staples/Office Depot. They have engineering printers, I just don't know about the software. You'd have to call first. I'll let you know on Monday how it goes.
    Dr Teeth likes this.
    Dr Teeth's Avatar
    Nov 2006
    Thanks MTX!!!
    Dr Teeth's Avatar
    Nov 2006
    It measured perfectly Jason. I can't thank you enough!
