Results 1 to 15 of 27
    thewagon's Avatar
    thewagon is offline Hurry up and get here Summer!
    Jun 2005
    Sparks, NV
    Exclamation Brakes "shudder" when light braking so did a Brake Rotors Runout Inspection
    Using OEM rotors and pads
    Ok, my brakes "shudder" typically under light braking, most of the time. Installed new set of pads, still shudder.
    Installed a different set of stock rotors, still shudder.
    Is the runout indicated a cause of the brake shudder? Would the R1 rotors run truer than this?
    The dealer mentioned even new oem rotors could not be true and they recommend cutting the NEW rotor on the car when first installing them...$150 for the fronts. WTF?
    Dealership says to check runout, here is what I found:
    Setup like this
    Dial indicator
    Video of the variation on the rotor surface
    2005 Inferno Red Magnum R/T & 2010 RAM 1500 4x4 Hemi
    Retired USAF/USANG 22yrs, Det 2 23ADS, 274th CCSQ, 213th EIS
    Phil Hunter is offline LX Padiwan
    Aug 2005
    Temecula
    I assume you checked your tie rode ends to make sure that none of them are worn. A bad tie rode end can also cause the shudder you are experiencing. Just another thought.
    Phil
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    Interesting test. I wonder what the normal "good" rotor tolerances are? I mean they're not perfect down to the micron - I wonder what the range is.
    Are we looking at .055" right there? 55 thousandths? One full revolution on the main dial would be 100 thousandths, or .100"? Do I have that right?
    Monster's Avatar
    Monster is offline ME-(I don't see the resemblance)-OW
    I'm That Neighbor You Hate!
    The runout looks to be about .005" - .006" from what I see on the video. This is about the thinkness of 2 pieces of paper. I'm not really sure if this is bad or within tolerances. If I were to guess, I would say that it looks good. Everything has a tolerance, nothing is zero tolerance. And the way that the needle moves slowly over a long section of the rotor and not a quick jump from high side to low side.
    Andrew, you might want to check the inside surface of the rotor too. One side could be fine, but the other side be bad.
    BTW Andrew, I think the shudder your feeling is from those dead bodies that you have rolling around in the back. Try securing them better and your troubles will go away. J/K
    I Am Not A Complete Idiot!!! (Some parts are still missing!)
    r1concepts's Avatar
    r1concepts is offline Supporting Vendor
    Dec 2006
    Those numbers looks good, and shouldn't be making the car "shudder". Do some inspections on your tires/tie rods/joints. The LX platform is known to have these issues,especially on the 05's.
    PERFORMANCE BRAKE PARTS
    1-888-712-6623 ext. 7006
    steven@r1concepts.com
    *Current forum rotor and pad deals: http://www.lxforums.com/board/showth...02#post2994702
    Mighty Noid's Avatar
    Mighty Noid is online now time to paint the car soon!!!
    Aug 2005
    SoCal
    r1.... thanks for stopping by and giving us that info...
    Thank you Bigal470
    Todd TCE is offline Supporting Vendor
    Nov 2004
    Didn't look at a video but .005-.006 is not outrageous. Over .010 and I'd have some concerns. I'd like to see some pics of the rotors, both sides of them to make more comments. Does the pulsation come and go? Was it there after something that was done such as alternate rotors, pads or even wheels with centering rings?
    If that dial indicator was set at 0 and is now at .055 that's huge!
    TCE
    Your one stop...for Wilwood brakes.
    Aug 2005
    SoCal
    Hey Todd... I forgot to wish you a Happy Birthday yesterday!!! My bad!!
    Also thanks for stopping and letting us know what you think and giving him so more things to check out!!
    Thank you Bigal470
    NYC
    Interesting test. Where do you guys get these wonderful toys??
    2006 Dodge Charger RT - 6.1L motor, 3.06 rear, Brembos, SRT steering & electronics * KWV2 suspension * Hotchkis sways * BWoody endlinks * SRT fascia & spoiler * Trufiber SRT hood * MSRT wheels * 6000k HID lows/fogs * Aftermarket LED headlamps * MyGIG * 1ST COMPLETE '06-'08 INTERIOR CONVERSION * AFE Stage2 CAI * catless mids * 170 tstat * Predator 93oct tune... & a bunch of other sh!t I cant remember!
    fnkychkn's Avatar
    greasy cardboard box
    brake rotor runout will eventually cause thickness variation. rotor thickness variation will cause brake shudder. runout, on it's own, should not cause shudder. ensure mounting surface is clean and turns true. might have to match-mount the rotors.
    btw, front rotor specs for '05 RT (18") are 0.0014" for runout and 0.0004" for thickness variation.
    srtjohn's Avatar
    srtjohn is offline Chrysler Chassis Master+,ASE MasterTech
    Nov 2007
    Redondo Beach, Ca
    Quote Originally Posted by r1concepts View Post
    i disagree with this!
    i have seen rotors that have exesive runout and no thickness varation that have caused brake pulsation! i do agree that left unrepaired rotor runout will cause thickness varation. but brake pulsation is casued by imperfections in the rotor pushing the pads back. could be runout or variation.
    i would check all 4 rotors, also 0.05inch isnt ok- if you have replaced rotors and it still pulstates i would remove rotors and measure hub runnout (where rotor mounts to hub) also its recomended that while measuring runout that the dial indicator be mounted to the car!
    if hub runout is good than try match mounting.
    sulzerdrone's Avatar
    sulzerdrone is offline I killed the electric car...
    Oct 2008
    S**ttywack, B.C., Canada
    5 thou. runout on your rotors shouldn't be a problem. We allow 2 thou. shaft runout on a pump for a nuclear reactor.
    E&G classic grill,Tint, custom fibre glass sub eclosure, Kenwood eXcelon DDX812 head unit, Alpine PDX 1.600 amp, JL audio W6 12" sub, A buttload of trunk rattles, Airaid CAI, Predator 93 octane CAI tune, and Eibach 1.5" lowering springs.
    I hate to advocate sex, drugs, violence or insanity to anybody, but they've always worked for me.
    - Hunter S. Thompson
    Aug 2005
    SoCal
    I think that Andrew needs to take his Magnum down to Torrance... LOL
    Thank you Bigal470
    thewagon's Avatar
    Jun 2005
    Sparks, NV
    Thanks everyone for your input. I would like to add some more info but I need to get ready for tomorrow first. A bunch of us are going trap/skeet shooting in about 7hrs. I'll add the info and thoughts Saturday afternoon.
    You guys all
    Aug 2005
    SoCal
    Oh thanks for the invite Andrew... You know that I want to shoot shot guns....
    Thank you Bigal470
