Page 1 of 6 123 ... LastLast
Results 1 to 15 of 86
    FactoryD's Avatar
    FactoryD is offline Gettin' high on the downlow
    Nov 2005
    Phoenix, AZ
    Unique AZ LX Event
    Birth of the first Arizona LX Club 426 HEMI
    Who would be interested in this?
    Would you like to see the beast come to life for the first time while hanging out with friends?
    Do you wanna slap someone on the back to see if their face will permanently stay stuck with a HUGE smile?
    Stay tuned. Details to follow...
    Fast56k's Avatar
    Fast56k is offline I ain't no FRI baby!!!
    Mar 2006
    Do I know who this is?
    So far DanRealtor, FactoryD, and Junior have offered to turn some wrenches. No other LX club has done anything like this. Let's be the first.
    C.
    Silver 06 CSRT-8
    Fast56k's Avatar
    Mar 2006
    I have the motor shipping stand they require to ship one. I have a feeling there are going to be a number of these fire breathing dragons running around in the not too distant future.
    C.
    Silver 06 CSRT-8
    Brilliant R/T's Avatar
    Brilliant R/T is offline Live To Ride/Drive To Live
    Jun 2005
    Phoenix, AZ.
    BobF's 6POINT1's Avatar
    May 2004
    PHXAZ
    My dad's got a bitchin' set of tools. I'm in!
    Fast56k's Avatar
    Mar 2006
    Quote Originally Posted by fullofit_ View Post
    I will help with all I can offer, heck I'll even put the sawzall in the closet at home.....
    Do you have a nice shop for this event yet C?
    Working on it. Junior said we could maybe do it at the Meister's house. I am looking into getting a bay at my local shop. They may help as well.
    Here is what is on the agenda:
    1)Remove Radiator
    2)Remove Alt and pwr steering pump
    3)Unbolt tranny from motor
    4)Unbolt exhaust from cat back
    5)Remove orig motor basically in tact
    6)Replace torque converter
    7)Mount rear air filter for dual Tbody intake
    8)Install new short block
    9)Bolt on Heads and Headers
    10Bolt on rockers, etc.
    11)Bolt on dual Tbody intake
    12)Attach headers to cat back
    13)Bolt on accessories
    14)Make all remaining connections
    15)Add all fluids
    16)Fire at will
    If I can put the motor in with the headers on without trouble, I will have the motor completely assembled except for the intake and bypass a few of these steps. Anyone know if I can put the motor in with the LT headers attached?
    C.
    Silver 06 CSRT-8
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    Yessir! This'll be a good one... We can certainly do it here, lots of room for wrenching; pool and yard and BBQ in back... it's available if that's what you all wanna do.
    What do you guys think - start to finish according to Carl's list... 6 or 8 hours? I really don't know - but those of us wrenching could start early and folks could drop by whenever they wanted, and stay however long... Barbeque and swimming, whatever, throughout the day... sounds like a great time.
    We'll need to get a good list of parts and tools necessary so we don't get hamstrung by something small...
    This is gonna be good!
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by Fast56k View Post
    C.
    I don't think so Tim, I seem to remember a little SoCal party at my place for just about the same thing.
    So Jr. asked me to give you'll a heads up on a swap. A couple things I noticed, you don't need to do. Also, some of this may already know, but I'll say it anyhow.
    1: You don't need to remove the radiator. You do need to remove the fans.
    2: You should use the correct engine block lifting tool. I highly suggest this one.
    3: This may go with out saying, but remove the hood. Remove the shroud (were the wipers are) and stock strut brace. this will make getting to everything 10X's easier, especially the tranny bolts. OH ya, remove the intake too.
    4: Unbolt the engine mounts from below (at the frame). Remove all the ACC's from the motor.
    5: You can removee the entire block with heads and headers in place. Unless you have LT's. If you have LT's or are going to install LT's, you'll be playing with a short block for this portion of the swap.
    6: Be Very careful with the installation of the converter, pay attention and double check the install. Triple check the depth (placement) on the input shaft. Do this before you drop the block back in, or you'll be taking it back out.
    7: DO NOT FORGET THIS ONE, yup ole number 7!!!. ABSOLUTELY MAKE SURE THAT when you install the TC, you have a set of the mounts at the 6:00 position. After you place the block, you can turn the fly wheel to line it up, but you ain't turning the TC. So install the two bolts, leave loose, use the damper to turn the motor over to get the other 4 bolts in place, then torque them.
    8: Make sure you remove a plug from each cylinder, that way you can turn the motor over.
    There are a lot of steps I left out. But I shouldn't have to say them anyhow. Good luck and have fun burping your new born baby when your done. If you have any questions while your doing it, I'll PM Jr my #.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Here's couple pic's for ya.
    PHANTZM's Avatar
    PHANTZM is offline Formerly known as Suipsycho
    Arizona
    Yeah , it will be the first in Arizona though !! With more heads to get in the way as well , lol.
    Thanks for any help you have to offer us Brother Cam. It is much appreciated I am sure.
    1sicsrt's Avatar
    1sicsrt is offline LX Padiwan
    Phoenix, Az
    I'm in for this!!!! Gotta know how to do mine when it comes time!
    Redfox0099's Avatar
    North Charleston, SC
    C.
    Do you need pics of mine since you and I are the only ones who have this intake?
    How do you plan on wiring it from the front one to the back....?
    CHARGERSHED's Avatar
    CHARGERSHED is offline why not the fratzog?
    Mar 2006
    in the moment
    If we need any "special tools" let me know and I'll borrow them from the
    tool room...
    I'll turn wrenches with you guys also...
    Currently: "Vanessa" 2006 Charger R/T with all kinds of little details and a unique red bee stripe... just passed 100k milestone!!!
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Damn, you'll have more wrenches then there is car to work on. How cool is that!!.
    Hey, if ya wait until late August. We're doing another motor swap at my place. We'll race ya, SoCalRT and me against all you guys.
    1sicsrt's Avatar
    Phoenix, Az
    Even though we would have more muscle it would probably still be unfair since you have already done one.
