Results 1 to 14 of 14
    Jack Evers's Avatar
    Jack Evers is offline Car Fool
    Nov 2006
    Phoenix
    "Service Park Assist Module"
    Major situation here. Car won't come out of park and get "Service Park Assist Module" on EVIC. Stuck in my driveway.
    Jack Evers
    Phoenix, Arizona
    06 300C SRT-8
    FactoryD's Avatar
    FactoryD is offline Gettin' high on the downlow
    Nov 2005
    Phoenix, AZ
    Quote Originally Posted by Jack Evers View Post
    You need our resident Chicken .
    Good luck Jack.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    I just searched the manual, that did not pop up. Do you have any other codes??.
    fullofit_'s Avatar
    fullofit_ is offline katie, princess of Rue
    Nov 2006
    tempe az
    first do you have brake lights?
    and I will search some threads while you check
    full
    fullofit_'s Avatar
    Nov 2006
    tempe az
    Jack check this thread, if that is not it and you need to be someplace pm me and I will be on my way.
    all the best,
    full
    Transmission won't shift out of park; anyone any idea???
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Ok, just got done reading several things that could be the problem. Luckly, all of them have associated codes. Go do the key thingy for the EVIC display. Turn the key rapidly between on and AUX (do nt start the car). You need to do this three times and then you will see the codes pop up in the EVIC. Let us know what shows up.
    fnkychkn's Avatar
    greasy cardboard box
    ensure stoplamps are functioning properly. if not, check fuse 19 in PDC (power distribution center/rear fuse box). in the meantime, you can use the override button on the side of the shifter to get you mobile.
    Quote Originally Posted by fullofit_ View Post
    all the best,
    full
    that thread was for 42RLE transmission shifter. BTSI (brake transmission shift interlock) operation is different for NAG1 transmission.
    Jack Evers's Avatar
    Nov 2006
    Phoenix
    Got It!!
    Fullofit convinced me that I should hook up fan switch and I was working on that circuit. When I got the car it had a blade connector pushed in along side of fuse 9 (15 Amp). I wired the fan switch with an Add-A-Circuit on fuse 13 (previously empty) so I figured I didn't need the blade connector stuck on fuse 9 and pulled it out. Turns out the fuse panel was distorted from jamming the blade connector into it and after I pulled it out the no. 9 fuse was not making contact with the fuse panel and I must have had an open circuit.
    This turned out to be a pain in the ass as the park assist module along with certain brake circuits are on this fuse. When I started the car I got an EVIC message "Service Park Assist Module." The car wouldn't come out of park and I wasn't going anyplace.
    FIX: Jammed the blade connector back into fuse 9 along side the fuse blade. That reestablished the circuit and everything works again.
    BAD NEWS: I've got that stupid brass blade connector sticking out of fuse 9.
    GOOD NEWS: My fan switch now works. I've tapped into fuse 13 so I can continue to run the fan after I shut the car down.
    Thank you all for your responses. I was sweating this for a while.
    Jack Evers
    Phoenix, Arizona
    06 300C SRT-8
    Jack Evers's Avatar
    Nov 2006
    Phoenix
    I didn't realize there was an override button on the side of the shifter, fnky, I must be blind. Will go out an take a closer look.
    Jack Evers
    Phoenix, Arizona
    06 300C SRT-8
    fnkychkn's Avatar
    you need to remove the little cubby pocket to the right of the shifter to expose the access hole. the lever is PINK.
    gn300's Avatar
    gn300 is offline Tipmaster G
    Nov 2004
    Nova Scotia canada # 1313
    So there is an interact between the brakelights and the shifter?
    Oh those Germans!
    Jack Evers's Avatar
    Nov 2006
    Phoenix
    The wealth of information available on this forum is amazing. Pulled the plastic liner out of the rectangular cup to the right of the shifter and there was the pink handle of the interlock override. Thanks again, fnkychkn, that could come in very handy if I ever need it again.
    Jack Evers
    Phoenix, Arizona
    06 300C SRT-8
    Jack Evers's Avatar
    Nov 2006
    Phoenix
    Shifter Interlock Override (photo)
    Jack Evers
    Phoenix, Arizona
    06 300C SRT-8
    fullofit_'s Avatar
    Nov 2006
    tempe az
    Jack,
    I am happy to see you got that taken care of. When we were at the last event and you asked me about this, I had no idea that it would put you in such a tight spot. I hope the mod works well enough to justify the increase in blood pressure.
    all the best,
    full
